g g 40 heads
g g 40 heads
Dropped my 302 off at the machine shop the other day for hot tank, magnaflux, and have the cylinders bored out. Figured I would ask about heads. He said I would be better off with my budget of around 3000 to just rebuild my stock heads (68 Cleveland block) rather that go with aftermarket or even gt40s. This is contrary to what I have read about heads for these 302s. What do you guys think? I'm leaning toward at least swapping for the gt40s
as they are a lot better than what I have according to what I have read. This is my first build so any info would be greatly appreciated. Thanks
Last edited by BryanMichael1989; 03-27-2014 at 01:46 PM. Reason: wrong title should read gt40 heads
Depends on how you're going to use the engine. Stock heads, even older ones, don't breathe well. But if you never go over 3,500-4,000 rpm you won't notice much difference from better heads. If you're planning to spin it you'll want something better.
Older heads may need more work will cost more to rebuild if they need new exhaust seats, studs, etc. With some porting they can support pretty decent HP, though.
Right now they are just going to hot tank everything and magnaflux the block and heads then if everything checks out the block will get machined. Supposed to sit down next week and go over cost and what direction we are gonna go with it as far as the top end. Right now for the hot tank and magnaflux 100$... If their labor on the rebuild is reasonable I'll have them do it if not I will. I'll know more next week. They are really busy right now as racing season is starting and they do a lot of motors for the guys here in stockton but it should still get done faster than it would if I do it myself with my schedule being what it is
Justin Braun
10-22-2017 09:47 PM
klatt_89
07-08-2006 11:10 AM
army_guy
01-07-2006 04:41 PM
marilyn
04-02-2005 09:44 PM
