Is my engine totalled?
I've not worked on many of the FI systems, although there are tests to be run that would help figure it out. But, before doing that I'd like to hear from some of the others to see if they think my theory is all wet or not. I'm known to have some ..... bizarre ideas, so let's see what others think.
But, in the interim, have you had any warning lights coming on?
I'm not sure about the oil leak, please post some photos if you could.
But what your description of the engine running rough before not starting and now starts then "locks up" with a bang..... sounds like it jumped the cam chain to me.
With all the cranking trying to start the engine, it very well have flooded up(black wet spark plugs) and if the engine jumped timing on the cam, it will never clear out. I had this happen on my 89 F250 when the 302 ate the cam sprocket.
Best to do a compression check, that will tell you alot!
have in each cylinder.
There are two types of mechanics. you got your parts changers... guys that spend money and put in new parts to see what they do.. and you got guys
that do a diagnosis.. You need compression, fuel, and spark.. all happening at the correct time in order for an engine to run..
I still think you should get a tester and find out how much compression you
So I finally got a chance to take a look at the truck again, been busy the last couple days. Anyways, I did a compression check; cylinder 1 read around 90 psi, #2 was 120, #3 was 125, and numbers 4-8 were all around 145. Also, the first few times i turned the engine over cylinder 8 spewed gas all over the place, and when i say spew i mean enough for some gas to hit me in the face from 4 feet away. After I put the plugs back in I tried finding where the oil leak was coming from, It seems to be coming from the main seal underneath the truck. I don't have the know how or the extra money at this time to fix these issues, so it looks like i'm gonna be taking the old girl off the road this week. Regardless, I appreciate everyone who tried to help me figure out what the issue was, hopefully one day I'll try to get her running again
#28
If you have that much gas in the cylinder then maybe my theory isn't so far-fetched. Pull the dip stick and smell the oil and check the level. If it is high and smells like gas then you may be squirting huge quantities of gas in via the injectors. That would cause it to run poorly, if at all, and potentially to hydro-lock while cranking - until the gas runs down past the rings. And, if you put enough in the crankcase then when the engine turns over it has to go somewhere.
So, just pull the dip stick and check the oil level as well as the smell/feel.
#29
You found your problem!! Cylinder 8 injector is leaking badly to cause that! It is not a ECU issue as the ECU fires 4 injectors for each "bank" and if no other cylinders ejected gas out while doing the compression test, I'd replace #8 injector and do a oil change also Like Gary said.
Years ago, I had a 2-smoke dirt bike, carb flooded the engine crankcase full of fuel. I took out the plug and my dip %^^% friend kicked the thing over as soon as I got the plug out. Got a face full of gas and that WAS NOT FUN at all. 20 years ago that stuff burns eyes, I hate to get hit with this "modern gas" the way it smells.....
#30
