voltage 97 ford f150
I have an off the wall question. what is the voltage suppose to be? I just bought a new battery and I tested it and it is showing 13.5 volts, when I hook it up in the truck I get a reading of 18.5 to 19.5 volts, why is this and how is it? I also tested obd II scanning port the bottom right pin the power pin cause I am unable to get a scanner to connect to vehicle, and it also gave me a reading of 19.5 volts. how is this and is it correct? thank you and any all input is so much appreciated.
dnkensinger
17
06-02-2017 06:51 AM
chasthanhburns
09-09-2015 05:03 PM
