Operating voltage
Old Aug 12, 2010 | 04:21 PM
jetact's Avatar
jetact
Operating voltage
I got worried as I checked my voltage with my Insight CST and it was 11.8v. I started the truck and after running for a minute or two it was at 13.0 v. That didnt seem right so I popped open the hood and checked hte batteries and alt. The batts were are 12.6 to 12.8 just sitting and after the truck was started I checked the alt and it was roughly at 14v. Does all of that seem normal? Why is the CST about a 1 volt lower then the actual reading? Any ideas?
Old Aug 12, 2010 | 06:31 PM
cheezit's Avatar
cheezit
well your volt meter readings sound good.
so far as the cts. is it reading b+, Vbatt, Vpwr? the reason I ask is it possibel to be reading the right value and you are using the wrong pid.
Old Aug 12, 2010 | 06:39 PM
jetact's Avatar
jetact
I just went and looked and all it says is battery voltage. I looked all through them and that was the only one to do with voltage. The have an information button and all it said was battery voltage also. Could the CST be defective?
Old Aug 12, 2010 | 06:40 PM
cheezit's Avatar
cheezit
At this point I would call them and ask. I cant advise at all on that product, I have not had a truck come in that has one for me to check out
Old Aug 12, 2010 | 06:43 PM
jetact's Avatar
jetact
Thank you. I will contact them and post what I find or get as a response.
Old Aug 13, 2010 | 01:56 PM
jetact's Avatar
jetact
Edge said they are aware of the problem and are currenting testing a fix/update. Funny thing is I got my SCT X-3 and put a tune in today and the CST seems to register the correct voltage. I emailed Edge and they didnt have a clue as to why but will send me a update when it comes out of test.
