More 6.9 Question PLEASE LOOK
okay I got the ol beast to run
rebuilt injector pump
new fuel pump
diffenrt injectors
but the stupid thing is ether addicted
I have check ed the glow plug they will lite the tester up but how many oms are they supposed to flow??
I also took the wire off the glow plug and it will turn the light on is there any thing else to check
I will need to get it fine timed but it won't start without ether after it has ran 10 minutes???
also I got 3 injector still leeking how do I fix this???
new fuel pump
diffenrt injectors
Howdy,
When you test the glow plugs with an ohm meter, you should read 2 ohms or less. Anything more than two ohms and you should replace the glow plug.
As for the leaking injetors, it's probabely the leak off tees on top of the injector. Replacing the tees and both orings under the tee will more than likely fix the leak.
Hope this helps.
Gr8ride
Hope this helps.
Gr8ride
How close do you have the timing set to spec? 10 minutes isnt enuf to get the engine to start without glow plugs (in my opinion) and you may be having a problem with the temp sensor that controls the glow plug controller.
Everything else is about what I would guess.
I wouldnt use too much ether - it could make a boom and that would make you unhappy.
on my injector leaks i just had to replace the o rings. It ran a whhole lkot better and smoked ess if your injectors suck in air your truck will smoke bad and run like crap so just let it idle and check for the leaks then replace the o rings at the leaks.I also have a push button rigged up for the glow plugs and if you have one to they easily burn out or have your glow plug switch in your ignition checked out.
DieselScoff
16
05-27-2013 04:49 PM
dtgl90vt
15
10-19-2012 08:25 AM
kpwall
13
05-12-2012 09:36 PM
92F250Excab
04-19-2011 10:35 PM
