project wompum truck
I have a 95 f250 eclb it needs extensive cab floor work. patch panels are expensive an cheap made I figured what better than oem replacement. So I got the floor out of the remains of a very nice florida truck that didn't last a year in pa kid swerved to miss a deer. Hit a sluse pipe and went a#* over tin cup twice and barrel rolled four times so I've made my own patches for bed made my own cross member drilled spot welds the whole way around donor floor and pulled rockers cab corners door posts and fender tabs now I'm at point of how to take my cab apartt to put new stuff in pulling the cab will make life easieer but how do I allign everything the pinch weld across fire wall and rear of the cab should lign up but what about piecing in rockers and door post should I do this first will add pics when I learn how thancks for any input
I tried to paste one to my post and couldn't do it. In that gallery, they don't allow links?
https://www.ford-trucks.com/forums/m...pum-43187.html
You can't post pics til you get 10 posts. That's the problem.
682bear
01-16-2017 06:36 AM
toast729
04-26-2010 08:09 PM
66 twin i
08-15-2009 05:00 PM
rtcalabrojr
13
01-13-2008 12:31 PM
