are all OBD codes the same no matter what vehicle the 5.4L is in??
Old 03-06-2014, 09:54 PM
Truckie256's Avatar
Truckie256
Truckie256 is offline
Question are all OBD codes the same no matter what vehicle the 5.4L is in??
(Yes I messed up its a 4.6L not a 5.4L)
I just bought a 2005 CVPI with 4.6L ( I asked in the crown Vic forums but not a lot of folks on that forum)
seems to run great!!
only codes I pulled are P061B and P2106 what are they?
I guess they could be OLD CODES from a previous issue and were not erased....
are the codes engine or vehicle specific?
any help would be great
Old 03-07-2014, 12:10 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
From the '05 PCED for the CV:
P061B - Internal Control Module Torque Calculation Performance
Description: Indicates a calculation error occurred in the powertrain control module (PCM). This DTC is set in combination with P2106.
Possible Causes: See the possible causes for DTC P2106.
Diagnostic Aids:
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to QE1 .
P2106 - Throttle Actuator Control (TAC) System - Forced Limited Power
Description: The TAC system is in the failure mode effects management (FMEM) mode of forced limited power. This DTC indicates the FMEM action is in effect due to a failure in an electronic throttle control (ETC) related component or module.
Possible Causes:
Diagnostic Aids: This DTC is an informational DTC and may be set in combination with a number of other DTCs which are causing the FMEM. Diagnose other DTCs first.
All GO to QE1 .
If there are no current or known recent issues, reset the PCM and drive it normally to see if any faults return.
Old 03-12-2014, 06:51 PM
Truckie256's Avatar
Truckie256
So far so good.... the code must have been old codes, they have not returned
Old 03-18-2014, 12:29 AM
MJE426's Avatar
MJE426
MJE426 is offline
Try the Crownvic.net. I've been a member there for a couple of years now, it's a pretty good site.
Truckie256
1999 to 2016 Super Duty
03-12-2014 06:52 PM
Pablo-UA
Aerostar
11-07-2006 12:35 AM
cathlabdog
10-25-2006 07:20 PM
choppersinc
1983 - 2012 Ranger & B-Series
03-01-2005 08:29 PM
RobertJohn
12-15-2004 09:34 AM
Quick Reply: are all OBD codes the same no matter what vehicle the 5.4L is in??
