parts, and trucks
parts, and trucks
Category: Accessories
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude
Item Condition: GA
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
1. 77 f100, 351M, auto, power steering, disc brakes, truck has 89k actual miles, has been sitting for a few years, runs rough. 1200.00
2. 77 f150 4x4, 351M 4x4, 4 speed, new headers, new radiator, runs but needs carb work, body is rough, good parts trucks or beater truck for the woods. 1300.00
3. 77 f250 high boy chassis, frame, front end, rear end 4.10's, front and rear springs, steering gear box and slave cylinder, 4 speed trans. will sell all for 800.00 or will part out.
4. 429CJ engine, was rebuilt, bored .030 over, balanced, forged pistons, has the football rod bolt rods, oil pan for 4x4. motor has less than 10,000 miles since rebuilt. I had removed the dooe heads and installed the PI d2oe heads for better low end torque. then later on it wiped a cam lobe. I pulled the engine apart. and cleaned it, installed a bigger cam, and decided while it was apart to replace all bearings, and that's where I stopped on it a few years ago. never bought the bearings, I did buy a stealth aluminum intake for it. will sell the engine for $1,300.00 the cj heads were sold years ago. The PI heads are great performance heads.
5. The granny four speed, and np205 transfer case that was behind the 429 will also be for sell. the trans was rebuilt and only has approx. 1500 miles since it was rebuilt, also have a centerforce clutch for it. $500.00
6. early bronco chassis 66-77, solid rolling frame, 9" rear /dana 30 front gears are 4.10's, six cylinder, three speed and t case, engine ran good when removed, its stored in my shop. 800.00 has a jeep wrangler body sitting on it, great project, I need 700.00 for the body.
contact me direct: jjjjjgrant@bellsouth.net call or text: 404-732-6550
dbdbb
05-14-2012 11:59 PM
