I will be installing my 351W in my truck soon, but I am not sure about the oil pan. I have a nice Kevko front sump pan, but I think I will need a rear sump pan. What would be a good pan to use?
I am assuming you want a front sump pan since you have a 4X2. 4X4's usually needed the rear sump. I personally have a used pan,dipstick,and tube off a 1976 Torino Elite 351W. If you're interested in a car 5 quart pan PM me. Or you can go with the ol' Econoline mid-sump pan. Also used in early 80's pickups.
I originally purchased this pan for my 66 Mustang, but got an offer for the car I could not refuse. I have a front sump 302 pan I can take measurements from and compare to the Kevko. If anyone could post a pic of their small block in their truck showing the cross member and pan clearance that would help a lot. Thanks
302's and 351W's take a different pan. The mounting surface is different.
The 302 pan is smaller in the main bearing and a little deeper in the sump compared to the 351 pan. I think the pan will fit now that I see the differences.
