1966 - 1977 Early Broncos
'76 steering knuckles on a '78 Dana 44?
Old 02-28-2014, 08:19 PM
300FOREVER's Avatar
300FOREVER
300FOREVER is offline
I have a '78 high pinion Dana 44 with no knuckles that I want to swap into my '76 Bronco....is this possible?
Old 03-06-2014, 08:29 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,288 Likes on 2,444 Posts
So you want to know if you can put the 5 lug Bronco steering knuckles on the 78 Hp D44....And then put/bolt that axle under the the bronco....right? Since I do not have the answer I can only suggest getting a tape measure first.
That would tell you real quick if it will fit, cause I believe there is a axle width difference, I guess it depends on that the radius arm C measure out to be between the 2 axles?
If you still had the knuckles on the D44 I would think that the spindles would transfer over? I know a 79 D44 F250 8 lug spindles/rotors will bolt right onto a 5 lug D44 axle easy enough.
And swap the single piston over to duel piston brake caliper.
Old 03-06-2014, 08:47 AM
300FOREVER's Avatar
300FOREVER
Yes, that's what I'm doing.
Old 03-06-2014, 09:03 AM
77&79F250's Avatar
77&79F250
Ok I am trying to do a little research for you...get the measurements for you. If I was home I would go tape measure them myself, I have both vehicles we are talking about, but I am OTR.
Old 03-06-2014, 09:32 AM
300FOREVER's Avatar
300FOREVER
I'm work now. I just need to measure them when I get home
Old 05-23-2016, 09:44 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
long ago
that didn't go far….
'hi steer 1 tun D44 in an off yr bronc' ('76/7).
Old 08-24-2016, 07:49 AM
Toyman's Avatar
Toyman
Toyman is offline
Yes it can be done. The long side needs to be cut 5.97" in the center of the tube, then use a sleeve to support that tube. After that it will bolt in.
Old 08-24-2016, 04:43 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
EB w/ '1tuns'
1way 2 get 1 tuns ina bronk. would bring in bout a 4 inch lift too, tho.
I'd use anyother '73 -9 (no hi pinion, F250) D44 in the frnt and weld a 6 lug
flange on a '66-'77 rear axel shaft 2 get '1tun' all around. Just don't like the
huge frnt discs that''d create. "Cut'n turn" would give U the proper width too - instead of a 'full width' in an EB.
Others have ideas on easiest, cheepest EB "one tons"?
87hambone3531
02-02-2018 06:46 AM
CraigOutdoors
03-17-2010 11:42 PM
nuckinfutsforfords
11-02-2009 07:25 AM
keeper
01-19-2005 08:18 PM
Playtime
07-20-2002 06:31 AM
Quick Reply: '76 steering knuckles on a '78 Dana 44?
