Calipers and banjo bolt clearance
Old 02-26-2014, 12:11 PM
jrockdiddy's Avatar
jrockdiddy
jrockdiddy is offline
Having problems screwing in the banjo bolt. The caliper is in the way. Can I grind or shave the caliper to make room? I've tried routing the braided line all directions. Doesn't work.
Also, is this correct for the washers?
Old 02-26-2014, 12:57 PM
Normalbloke's Avatar
Normalbloke
Normalbloke is offline
I'd get a different hose that fits properly! Not worth the risk.
Old 02-26-2014, 01:10 PM
ryans88gt's Avatar
ryans88gt
ryans88gt is offline
you can get those hose ends with a 45 degree angle
or... a thicker brass washer?
Old 02-26-2014, 01:12 PM
yamagrant's Avatar
yamagrant
yamagrant is offline
There is a lot of material on that caliper. I would, and have grinded away some of it to make the hose fit properly. Those are the proper washers. Good luck.
Old 02-26-2014, 01:23 PM
ryans88gt's Avatar
ryans88gt
Old 02-26-2014, 01:29 PM
jrockdiddy's Avatar
jrockdiddy
Old 02-26-2014, 02:22 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is online now
I would either grind the caliper, that is extra casting that can be removed or bend the existing fitting slightly, it is steel. You may get a hose and fitting store to replace the end if the hose is long enough.
Old 02-26-2014, 02:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
What calipers do you have, and what banjo did it have on the donor?
Old 02-26-2014, 04:08 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
I ground a half circle to clear, it worked fine.
Old 02-26-2014, 06:07 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,469 Likes on 1,408 Posts
While you may get away with grinding on the caliper to make the line work, somewhere out there is the correct hose for the application. What are the calipers from? Would it be just as simple to get the correct part?
Old 02-26-2014, 06:21 PM
jrockdiddy's Avatar
jrockdiddy
It's because my rear calipers are really front calipers. They are 78-88 gm metric calipers. The braided hoses are for that application. I bought both from speedway motors. I switched the front rubber hoses to the rear, and braided to the front. I believe it worked fine.
Old 02-26-2014, 06:40 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Check for a flare seat in the caliper's port. I would bet it was designed for a tube to screw directly into it. If so, a banjo isn't going to seal.
Old 02-26-2014, 09:19 PM
jrockdiddy's Avatar
jrockdiddy
Old 02-27-2014, 01:00 AM
Normalbloke
As long as the banjo bolt doesn't bottom out on the flare, and the copper washers seat flat, it'll seal perfectly.
Old 02-27-2014, 10:38 AM
The Outlaw's Avatar
The Outlaw
The Outlaw is offline
Put two more washers in place to help you gain the clearance. I had this issue on some of the master on my race bikes and adding additional washers fixed it. And trust me if I thought it would cause an issue I would not have done it. Messin with brakes on a bike that I would be hitting 180mph on was not something I took lightly.
AVR2
Escape & Escape Hybrid
12-12-2017 01:35 AM
JTB321
08-30-2017 11:59 PM
richardfine
09-12-2004 05:31 PM
Spooky
07-09-2003 12:43 PM
Quick Reply: Calipers and banjo bolt clearance
