Leveling Kit
Leveling Kit
I'm thinking of a 2" leveling kit for my 2012 SD, I did my last 08 PSD and needed a adjustable track bar to center the axle. Will I need to do the same on this truck? I currently installed F350 blocks and shocks on the rear and will put Air Lift bags on if I do the level.
Thanks in advance!
Thanks in advance!
on
1 Post
ya to center the axle you will need either a adjustable track bar or you will need a drop track bar bracket. also to keep everything else in line you will need the trailing arm drop brackets . i just bought the readylift sst level kit. has everything to keep
the front end in line . i got mine with the 5" rear blocks. shock extensions are only required if you go off road or longer shocks. i do believe they sell the kits with out the rear blocks . there called the f350 kit coz they have 4" blocks already, right now they will knock 10% off advertised price if you ask .so you should be able to get a kit for less than 400$
Post up some pics....... I also have a 2012 CC 4x4 and want a little bit of lift.
I always get confused by how they call it a "leveling" kit. I have measured and my truck sits damn near level stock.
So would the kit you bought also be what I would use?
Thanks!
shark1979
6.7L Power Stroke Diesel
23
12-08-2013 09:46 PM
madcatter33
03-13-2013 12:04 AM
