Squeaking Noise While applying Acceleration
Old 02-21-2014, 08:44 AM
billest's Avatar
billest
billest is offline
Question Squeaking Noise While applying Acceleration
My truck is making a squeaking noise when i press the gas i do not know what it is, but it is very annoying. It stops sometimes when i press the gas but it keeps going after a little while maybe while im in 3rd gear it will stop, I took of the belt to the smog pump as i thought that was the problem anyone have the same problem but solved? Maybe i can get it taken care of tom. morning. HELP!
Old 02-21-2014, 08:45 AM
billest's Avatar
billest
billest is offline
its a straight six 300
Old 02-21-2014, 12:04 PM
1986F150six's Avatar
1986F150six
1986F150six is offline
Check the tension of the remaining belts. Look at the underside of the belts and see if they are badly glazed. Do not overtighten them.
Does it seem to squeak [squeal] more when the air is humid? Does it make this noise immediately after starting the engine and then stop?
Old 02-21-2014, 02:28 PM
Brnfree's Avatar
Brnfree
Brnfree is offline
I had a fan clutch fail and it locked up. Caused belt squeal around 2700 RPM+.
Old 02-24-2014, 08:59 AM
billest's Avatar
billest
billest is offline
it only happens sometimes but yes squealing is a better word
Joshua Heinicke
01-28-2018 05:52 PM
FONRDAY
6.7L Power Stroke Diesel
05-27-2012 02:45 AM
labmaster
04-03-2010 04:26 PM
78bigbronco
1997 - 2003 F150
03-25-2007 10:57 PM
surfer8400
1983 - 2012 Ranger & B-Series
03-19-2004 09:56 AM
Quick Reply: Squeaking Noise While applying Acceleration
