Anyone know of national distributors who regularly stock Caterpillar ELC coolant, other than the CAT Dealers. Just trying to find a source closer and more convenient than the CAT dealer.
There's no way to completely get all the water out of the system even if you open the block drains. If you do a system flush, on the final drain you end up with 1/2 the system still full of clean water by just dropping the lower hose. If you add 3.5 gallons of straight coolant you end up with a perfect 50/50 mix of antifreeze and water. if you use the premix you end up with 25% antifreeze/ 75% water.
To get a 50/50 mix.
After you finish flushing with distilled water, there will be water left in the system. Add 3.5 gallons of ELC concentrate then finish topping off with distilled water. The system takes 7 gallons.
Expect a lot of questions when you ask for the concentrate. It seems we are the only ones buying it. It will also more than double the cost of the 50/50. I got mine at the CAT dealer. I was amazed at the reasonable price until I realized they had pulled the 50/50 - to save me some money and the hassle of diluting it myself. Hardest part of the project was getting the Restore, VC-9 and ELC concentrate. Turns out CAT sells a system cleaner that works like vc-9. Anyway good luck.
