1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Dana 50 hub help
Old 02-16-2014, 02:16 PM
BIGMAGGOTBILL's Avatar
BIGMAGGOTBILL
BIGMAGGOTBILL is offline
Dana 50 hub help
I have a 94 f250 4x4 ext. cab 8 foot bed with the Dana 50 4600 front axle. My original wheel hub on my passenger side was junk so I bought another one. Now my problem is it doesn't sit right on my spindle it woobles. Farther looking in to it. I see it does not match my driver side. Bought another one same problem. I'm not lost on all this. They both came off 90s Dana 50s. Even tried a Dana 60 hub no good. Can anyone shed some light on this?? Can't get my pictures to appear on here. I can email them if needed. Thanks
Old 02-16-2014, 03:07 PM
swoosh's Avatar
swoosh
swoosh is offline
You might try posting in the older body style forum, good luck, also if you still have the old 1 take with you to the parts store, agaim good luck
Old 02-16-2014, 04:26 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is online now
Do you have a regular F250 or a Heavy Duty F250? Even though both a leaf spring front TTB front axles the regular f250 has a Dana 44 version and the Heavy Duty F250 has a Dana 50 TTB axle.....
Sent from my iPhone using IB AutoGroup
Old 02-16-2014, 04:30 PM
BIGMAGGOTBILL
Heavy duty Dana 50
Old 02-16-2014, 05:18 PM
SuperDutyScaler
So the hub opening is too large for the dial to sit tight right?
Old 02-16-2014, 06:21 PM
BIGMAGGOTBILL
No bearing and race are to far back. There's a gap between the bearing and wheel seal
Old 02-17-2014, 12:51 PM
SuperDutyScaler
did you push the axle shaft too far in?
Ford3+
05-06-2016 07:15 AM
Hogtrapper
19
03-25-2015 12:34 PM
muleguitar
01-07-2010 09:07 PM
hilljackusmc
11-26-2006 09:03 PM
BondoFord
10-06-2004 10:53 PM
Quick Reply: Dana 50 hub help
