newbie suspension question
I just bought a 64 f100 4x4 and haven't got it home yet but was making plans and need to know about the front axle and suspension. is it solid axle, ttb, open or closed knuckle, leaf spring or coil, and drums or discs. thanks in advance. I am looking forward to doing this build and sharing on this site.
thanks guys. my 14 year old and myself are building it for his first truck, he want it bada$$ and I want it safe. disc brakes all the way around are a must. I have a set of excursion axles laying around that would work great and could swap them cheaper than doing the conversion an all 4 corners.lots of stuff to come
What year Excursion axles? Leaf or coil mount?
The later model (Super Duty) Dana drivers side drop front axles have barely enough room for a leaf spring perch, could be a problem with the narrower 64 frame if you were thinking about trying to retain the factory leaf spring mounts.
Spend some time over here if you want see some good examples of how any axle can be put underneath anything with some fabrication:
Pirate4x4.Com : 4x4 and Off-Road Forum - Powered by vBulletin
chucks65
16
01-29-2018 11:22 AM
Wilsons654xlb
13
11-11-2014 08:07 AM
BigTone9
08-05-2013 02:36 PM
red04gli
06-08-2010 02:49 AM
