Dual Snorkel Air Cleaner
Old 02-15-2014, 11:16 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
I'm not rich enough to afford one even IF it came up for sale, so I made one out of three air cleaners. The body is from an 80 something Crown Vic and the snorkels are from parts I found on the same Pull and Save trip. I even made ducts out of exhaust pipe reducers and held them on with hose clamps. Both sides have this treatment and will be functional. May not run any better, but it sure looks cool.
My fiscal outlook is dismal due to the Holidays, so this kept me busy.
Old 02-15-2014, 04:38 PM
spurredon's Avatar
spurredon
spurredon is offline
Tidy work. Looks like a space ship just landed on your engine!
Old 02-15-2014, 06:13 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
LMAO!!! I coulda put a chrome air cleaner for less money, but what's the fun in that?
Old 02-15-2014, 06:31 PM
spurredon's Avatar
spurredon
Definately much more personality!
Old 02-16-2014, 09:22 AM
hiball3985's Avatar
hiball3985
hiball3985 is offline
Thats a unique set up. But why would you want to add hot air to the intake
Old 02-16-2014, 09:25 AM
Choptopjimmy's Avatar
Choptopjimmy
Choptopjimmy is offline
I was wondering the same thing.
Old 02-16-2014, 10:05 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
When the heat riser setup is working correctly, the flaps in the nozzles flatten out so that air is blocked from the exhaust manifold/s when they reach a certain temp. IIRC it's 105 degrees or something like that. Prior to that temp the flap is up and let's hot air get to the carb. This prevents carburetor icing and ensures the choke is pulling off when it should. And yes, I'm running an automatic choke.
Old 02-16-2014, 10:35 AM
hiball3985's Avatar
hiball3985
I guess that helps in the frozen part of the country, something I always forget about. I remember many cars having that set up on just a stock single snorkel. Here in the southwest it was one of the first things that got trashed along with all the smog crap
Old 02-16-2014, 10:59 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
I live in the NW. Does get cold around here. I may figure out a way to open the flaps for summer.
Old 02-16-2014, 12:23 PM
hiball3985's Avatar
hiball3985
Are your's just heat controlled? I remember some that where vacuum controlled through a temperature controlled vacuum switch.
Old 02-16-2014, 01:05 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
The newer ones have the vacuum switch/motor on the top of the snorkel. I took that snorkel off the body of the one I'm using and used the heat controlled ones.
daveengelson
32
12-05-2020 02:12 PM
joe f350
08-30-2010 01:54 AM
RED BOMB
06-11-2008 08:01 AM
saltamontes
02-08-2007 04:54 PM
302FORDF100
04-08-2005 09:47 PM
Quick Reply: Dual Snorkel Air Cleaner
