Outside Rear Veiw Mirrors
#31
Ben, What are you currently using for mirrors that don't work? Are they the same mirrors that Chuck is using? I ask since I have a pair of the same ones as Chuck is using AND I plan to use them to pull an enclosed trailer (trailer sides inside the trailer wheels). When I got Willard, he had had the typical west coast mirror which I will not go back to.
#32
#33
I had the same mirror on my 38 Woodie back when and it was OK, however, I was not towing with it.
<center></center><center> </center><center>These were the mirrors that were on Willard when I bought him back in the late 70's. Great for trailering but they are long gone and will stay gone!</center>
#34
#35
I just purchased some and was installing today. I ground the hinge down to fit the mirror arm, tapered the new pin, thought that everything was lined up right, The pin went down ok but when I gave it a tap to set the splines on the pin the bottom of the arm broke. The arm looks like it is just chrome plated pot metal. I know that most of this repo stuff is just imported crap but I would like to get some quality mirrors and I don't mind spending a little extra for good stuff. I did not buy my mirrors from the vender that I got the picture from by the way.
I also found these larger stalk mirrors that I thought that I could use if I want to tow a trailer.
#37
#38
Motorcycle . . . Maybe Ross but I found them under a truck search.
EDIT: I found these square mirrors which should work. I think that they should fit on the curved hinge pin arms.
https://www.streetrodhq.com/detail/15882/Rectangle_Billet_Mirror_Head_Large.html
#39
Here is the mirror C&G is selling:
The arm can be extended, the angle of the arm adjusted, and the mirror itself can be unbolted. I think the mirror is larger in diameter than the more decorative mirrors discussed above in this thread.
Here is a close up of the hinge mount area. This mirror also comes with a hinge pin.
#40
Scotty's 52 F3
13
01-05-2016 10:23 AM
calorchard
12-13-2011 05:04 AM
laynrubber
01-24-2005 03:54 PM
