99 7.3 Overspeeds randomly when idling
My dad has a 99 F550, 7.3 obviously, and it acts fine except when its been sitting a long time and you start it up. It starts a little slow, but its cold right now so thats normal. Once it starts it seems to idle fine but if you leave it for a couple minutes to warm up it randomly starts speeding up and goes all the way to redline until you hit the throttle pedal, then it comes right back down to idle. We bought the truck in September and it never did this until December, so I'm not sure if it happened to the previous owner last year when it was cold. It may or may not have something to do with the cold, it may just be something wore out and it happened to be when it got cold. Any ideas what could cause this?
I haven't ever just let it do it and look at the tach so I'm not sure how high it revs. My memory is a little foggy because I haven't been there when it did it for a few weeks. I'm just wanting to figure it out because its happened to dad a few times in the last week. And I can't really ask him what it does because he wouldn't exactly provide informative information if you get what I mean haha he calls it a runaway even though I explained to him a real runaway is a lot scarier than that...
Shows how much I know about diesels... Sorry for the idiot post. I would've thought that if that was the case it would idle up as soon as it started up, like a gas motor does... Thanks though.
It's a function of the PCM, as Pikachu said. There is an exhaust back pressure valve, and the PCM commands it to close to heat up the engine faster. Then it will cycle on and off a little while and then it will stop once the engine oil temp gets up to about 150 degrees or you touch the break or throttle.
Till the end! My hat is off to you, Special Forces have had quite the full plate mission...... Everything inside & outside the box.....
Sondre Næss
02-20-2017 07:36 PM
Laser Red PGT
12-20-2001 03:13 AM
