1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
no crank no start help tried everything
Old 02-10-2014, 02:23 AM
Grady Whitman's Avatar
Grady Whitman
Grady Whitman is offline
Exclamation no crank no start help tried everything
i cant really post on the forum cant find my problem anywhere its a 2000 expedition 5.4L i replaced the battery, the starter, and the solenoid, i can turn the engine over by hand, and when i turn the key the starter clanks against the flywheel but wont turn over all the fuses are good and im completely out of idea's it started one day then bam hasn't cranked in 2 months
Old 02-10-2014, 07:10 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Test the battery and starter cables for excessive voltage drop when under load.
Old 02-10-2014, 09:30 AM
alloro's Avatar
alloro
alloro is offline
Received 4,196 Likes on 2,432 Posts
Follow the negative cable from the battery to the engine block and make sure it is tight.
Old 02-15-2014, 01:15 PM
pat49's Avatar
pat49
pat49 is offline
no start
Check connections on positive and negative battery cables at battery, block and starter. Test voltage across battery terminals when trying to start
if it stays above 10 volts check it at the starter between the positive
cable terminal and a clean ground like the starter case or the block.
If it's 10 volts or greater suspect the starter if not it could be the battery.
Try jumpers or charge the battery.
Skull buster
02-05-2014 05:09 PM
bigsky22
09-20-2009 08:45 AM
tealboy1
10-10-2004 06:42 PM
jln_Wasabi
Electrical Systems/Wiring
03-03-2004 10:36 PM
KLR650
05-15-2002 11:09 PM
Quick Reply: no crank no start help tried everything
