For a stock low performance engine like that I would think that Low would be from idle up to 2000 rpm, Mid from there up to 4000, and Top End from there to 5500. Most low performance engines make only noise above that point if they will rev that high.
Yea the highest mine has revved so far is only 4200. It shifts at that point. Factory redline back In the day was 5100. Max hp at 4600. Peak torque at 2600.
Just curious. I was looking at cams and was trying to apply low mid high descriptions to the rpm which they would use. Being that Ill never go over about 5,000. I need a good low and midrange cam.
