Ashtray conversion to drink holder
Old 02-05-2014, 07:50 AM
Tyler S's Avatar
Tyler S
Tyler S is offline
Has anyone converted their F1 ashtray to a cup holder? Wondering if its possible and practical...t
Old 02-05-2014, 09:04 AM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,059 Likes on 804 Posts
I don't smoke so I've converted my to a key holder, a junk box and numerous other uses.
Seriously, I never thought about that. It sounds like a good idea and I can't see how hard it would be to insert a plate with an appropriate sized hole to hold a cup. I don't know if it'd be big enough to hold a standard cup though.
One thing to think is the ride of these old trucks, I don't know if yours has a modified suspension but with my F-2 if I had cup full of liquid in the ash tray the contents would be flying out with every bump I'd hit. Better have a lid on it.
Old 02-05-2014, 09:09 AM
Doc's Avatar
Doc
Doc is offline
Agreed. The tray is too small. You'd have to do a lot of modifying or design something that slides straight out like a modern cupholder.
I will say this--I found that ashtray makes a great sound amplifier for your MP3 player, smartphone, etc. I was listening to Pandora on my smartphone back in the summer. I stuck it down in that ashtray. The sound amplification was pretty good. Try it!
Old 02-05-2014, 09:15 AM
Tyler S's Avatar
Tyler S
Tyler S is offline
Originally Posted by Doc
Agreed. The tray is too small. You'd have to do a lot of modifying or design something that slides straight out like a modern cupholder. I will say this--I found that ashtray makes a great sound amplifier for your MP3 player, smartphone, etc. I was listening to Pandora on my smartphone back in the summer. I stuck it down in that ashtray. The sound amplification was pretty good. Try it!
Hey, that'd be lot cheaper than a $1000 stereo system!!
Old 02-05-2014, 09:27 AM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
I installed a dual port power port in my F-2 so I could power my GPS and phone, I still have the stock positive ground 6 volt system. It worked great. Just recently I bought a USB speaker that plugs into the back of my phone charger, which has a USB port, and a jack that plugs into my phone. Now I can turn the volume up high enough to hear over truck.
Old 02-05-2014, 10:33 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is online now
You may want to reach out to Ben73058 - as I recall, he installed some swinging cup holders in a '50...
Old 02-05-2014, 11:08 AM
GLR's Avatar
GLR
GLR is offline
If you put a couple of old boots on the floor, they make good cup holders.
Old 02-05-2014, 12:41 PM
49f3dls's Avatar
49f3dls
49f3dls is offline
And they look period correct also
Old 02-05-2014, 01:37 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
One idea I'd like to offer is if you're not using the stock radio and speaker you could turn your speaker grill into a hidden cup holder. I've posted before about how a person I knew mounted the plastic speaker grill on a piece of sheet metal that followed the contour of the dash. He then hinged the bottom and use a spring loaded key chain to pull it back into position to hide a modern sound system control unit. You could do the same thing but install a couple of short pieces of PVC pipe that would fit the bottom of the cups. When not in use it would fold back up to the dash.
Old 02-05-2014, 04:59 PM
rhopper's Avatar
rhopper
rhopper is offline
My heat and ac controls are mounted where the ashtray used to be. I'm using boat cup holders that I've installed on the forward, upper portion of the doors, below the vent windows. They're the fold out type, available in any boat or camping store.
Old 02-05-2014, 05:59 PM
homade's Avatar
homade
homade is offline
I'm using tractor supply fold out tractor cup holders, about 3 1/2 in square, mount on door below cozy wing,about 3/4 in thick pulled down and spring fingers open up. Ofcourse they are black and with a small blue oval self adheasive logo they look right at home.
Old 02-05-2014, 06:42 PM
Tyler S's Avatar
Tyler S
Tyler S is offline
Hey Hopper can you post a pic of those on this thread? Thx in advance. T
Old 02-05-2014, 06:44 PM
Tyler S's Avatar
Tyler S
Tyler S is offline
Homade, my man, can you post a pic of your cup holders? Thx! T
Old 02-05-2014, 07:20 PM
bra$$monkey's Avatar
bra$$monkey
bra$$monkey is offline
I use mine as a phone holder - holds it perfectly so I can use the GPS
Old 02-05-2014, 07:52 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Same here. I also use an app on my phone for a speedometer, since my speedo is so far off calibration.
Quick Reply: Ashtray conversion to drink holder
