Aerostar Ford Aerostar
Speedo/toe
Old 02-03-2014, 06:30 PM
MilllerTime's Avatar
MilllerTime
MilllerTime is offline
Speedo/toe
Hello guys I've got two questions
1st
What the toe supported to be on our vans mine is a 93 2wd. I've heard 1/16th of an inch inwards in the front?
2nd
I'm running 70r tires and I thing it's supposed to be 75r or something. Anyways my speedo is off by about 5 mph on the interstate. My question is is it a electronic thing or does it actually have a gear? I have a 96 bronco and I put 35s on it speedo was way off but went in and reset it on the speedo. Didn't know if I could do this on the van to or if it has a gear
Thanks guys
Old 02-03-2014, 06:58 PM
93nighthawk's Avatar
93nighthawk
93nighthawk is offline
1st
I don't have the specs in front of me, but that sounds about right.
2nd
Thanks guys
What size rims are you running? Factory?
OEM wheels/size were 215/70r14 with optional 215/75r14.
As for adjusting the Speedo, the cluster is the same in your Aero as what is in your Bronco. The clusters interchange between the F-series/Bronco/Aero of that era. You can adjust the PSOM by pulling the cluster and looking at the back of the Speedo.
Old 02-03-2014, 07:04 PM
MilllerTime
Running stock wheels and thanks I think this will help
1950gmcelc
02-16-2009 01:57 PM
tai-tanium
05-04-2004 01:17 PM
turbonatr
1978 - 1996 Big Bronco
03-11-2003 11:24 PM
JBronco
01-05-2003 06:21 PM
Quick Reply: Speedo/toe
