1995 7.3L F-250 Idles rough,white smokes, OBDII not working
Hello, I have a 1995 F-250 7.3L that I just purchased and it's not in running condition. It will start up after jumping off and using ether (which I hate doing). But after starting up it will white smoke, and bog down. It will not reach over 3K RPM without bogging down and dying. After it dies it won't start up again for awhile. I tried hooking a genisys scanner to it but it says communication error. I used a test light Nd it shows there is power, but still no signal. I replaced the CPS thinking that was the case but it didn't do any good.
Any suggestions as to what I should do?
By the way there is a ts-6 which was put in a year before I had purchased the truck, was also told there's a new motor with under 25k on it.
Please Help!! 😔
Please Help!! 😔
Have you done anything to the truck? Start out by changing the fuel filter, and cleaning the fuel bowl. Also gently clean the fuel regulater screen. You will find it on the upper drivers side of the fuel bowl. See if the fuel in the bowl is clear, not black and oily. Check the fuel pressure via the schrader valve. If you can, check it while the engine is running. You should have at least 50 lbs. while the engine is running. If you can't check it with the engine running, you can check it while someone cranks it over. I don't recall the minimum pressure while cranking, somewhere around 20-30 lbs. I think. You can use a cheap pencil type tire gauge. Just a couple of things to start with.
Also most generic readers will not communicate with the stroke computer.
Put the keys in your pocket and take the chip out first thing. Then check what Tom mentioned, take note how the fuel looks in the fuel bowl. It must have a check engine light so it would be nice to see the codes.
Welcome to fte by the way.
As for the water pump, 94-95 use a short stem stat, and 96-97 use a long stem.
Okay Madpogue will do thanks for the heads up.
No ticking, just a click when the relay engages. You need to check voltage on both of the big post on the relay to confirm it is working properly. One post should be battery voltage all the time and the other big post should read the same with in a half volt or less. Check this right after you turn the key on cause the glow plug system only runs for around 2 min after you turn the key on.
choppycam
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
08-18-2009 01:58 PM
