fuel filter on engine leaking from small access port?
Ive noticed a pretty significant leak of diesel under the truck when running, and tracked it down to the small round allen head port at the bottom of the fuel filter attached to the top of the motor.
What I cannot find for the life of me, is a replacement part for this?
surely its not just a regular oring? is this a ford dealer only part?
thanks in advance.
thanks in advance.
Yeah, that's a LOT for an o-ring. Maybe someone here has a plug removed and can measure an o-ring that wasn't leaking for you, and you can source one from a local shop. Even buying a set of rings is cheaper than a new plug apparently.
180 Piece Viton O-Ring Kit
Could also be the "keyhole" shaped Oring on the regulator cover. Great time put a blue spring in there if you haven't done it yet.
https://www.ford-trucks.com/forums/1...ue-spring.html
99ExpyProblems
07-29-2013 12:37 PM
mhancock2
09-20-2011 09:41 AM
