Mechanics Please help! Crank no start after fuel filter replacment!
Stated with a sluggish drive (weather went from very cold to very warm here in NJ) i figured condensation or bad gas....added Diesel 911, helped a bit till i got it home (truck wouldn't go over 40mph)....pulled fuel filter on frame rail A LOT of powdery silver metallic looking flakes spilled out....changed filter/drained h20 valve, then changed 2nd filter on top of motor.....Crank NO START what so ever....This is on F550 dump, NEEDED DESPERATEly on job site asap!
Any help appreciated!
NOTE: I cranked over motor and watched fuel bowl on top of motor fill with fuel, so im ruling out fuel pump?
Thanks! Matty
Have a look at this post https://www.ford-trucks.com/forums/1...l#post11418266, it might be worth a try. Based on the symptoms you're describing, it might be worth a look at the secondary filter to make sure it was installed correctly.
The silvery flakes aren't magic fairy sprinkles that appear only on bad o-rings...
Josh
yeah...i get it whats with the sarcasm, im far from an idiot. The reason it didnt start IS BECAUSE OF A BAD O F I L T E R O R I N G. I will deal with the tank now
Lol magic fairy sprinkles, I think mattys main worry was getting the truck rolling down the road. I dont think you meant anything rude by that. Just trying to make sure he didnt just forget about it.
