What headers for a 351
Old 01-10-2014, 07:27 PM
ohbrian's Avatar
ohbrian
ohbrian is offline
I have a 56 with a 351 cleveland about to go back in. I was wondering if anyone is running headers other than sanderson? I'm having a hard time finding all the measurements to determine if they will fit in there without issues.
Old 01-13-2014, 02:16 PM
bra$$monkey's Avatar
bra$$monkey
bra$$monkey is offline
nope - good ol' cast iron on mine.
I want to change them out because all the non-car people I show off to say - "it's all rusty" - drives me crazy - shiny crazy custom made up truck & all they see is the darn cast iron header
Old 01-14-2014, 08:26 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Keep us posted on what you end up doing. I'm thinking about changing my cast iron manifold out too.
Old 01-14-2014, 02:16 PM
dale waddle's Avatar
dale waddle
dale waddle is offline
351c headers
I used 71 mustang mach 1 headers on my 54 f100. they fit fairly tight to the block but were not hard to install. I have transdapt motor mounts and had to grind 1/8 " off them to clear the bottom tubes. I also had to cut a 1/4" notch in the passenger side header exhaust extension flange to clear the transmission oil pan.they are also close to the frame mount brake master cylinder and power brake unit. I used hedman s-bend style universal exhaust extension - they make it much easier to line up your pipes. I would recommend using header wrap on at least the lower pipes to keep heat off the brake unit, the starter, and transmission pan.
dale
Old 01-14-2014, 03:10 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,450 Likes on 1,397 Posts
Before you toss out the iron mani's, try coating them with this. Brush it on and let it bake in. Works good, looks good.
Eastwood Silver High Temperature Exhaust Coating Paint Kit : Amazon.com : Automotive Eastwood Silver High Temperature Exhaust Coating Paint Kit : Amazon.com : Automotive
Old 01-14-2014, 03:34 PM
bjmayberry2
dale
I bought a pair of 351C 4 barrel headers at a swap meet but haven't tried to install them. Their pretty banged up and they were cheap but the seller didn't know who made them. Thought I might be able to make them work when the time comes.
Old 01-14-2014, 07:14 PM
DGMFORD's Avatar
DGMFORD
DGMFORD is offline
I have a 1986 351w in mine, and was not successful on headers, I'm using the Toyota PS kit and on the drivers side, not much room with that gear box.
Old 01-14-2014, 08:34 PM
ohbrian's Avatar
ohbrian
ohbrian is offline
Thanks guys!
Old 01-15-2014, 01:54 AM
Mervy49's Avatar
Mervy49
Mervy49 is offline
I installed Sanderson's huggers on my 351w and it was really tight with the Toyota box. I have the engine dead center in the frame and there's not much clearance on either side but they do work.
Old 01-15-2014, 04:20 AM
Aarons54f100's Avatar
Aarons54f100
Aarons54f100 is offline
I run dougs shorties on mine.
Old 01-17-2014, 08:52 PM
firstrider's Avatar
firstrider
firstrider is offline
But do not use the wifes oven to bake them . Trust me on this one !!!! Her's was new , I bought it for her ,so I figured some rights to use it were came with it . WRONG!!!
Old 01-18-2014, 07:38 AM
48 Steel's Avatar
48 Steel
48 Steel is offline
Also running Sandersons. I had them coated with Chromex High temp.
_________________________________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"If it don't go, chrome it"
4speed_thing
17
01-05-2011 05:08 AM
agthomas2
13
12-03-2010 09:46 PM
Drew2010
01-23-2007 06:06 PM
56 Ford Trucker
12-28-2004 09:32 PM
78custom
05-19-2003 11:04 AM
Quick Reply: What headers for a 351
