Aftermarket LSD or locker choices?
HI, I want to upgrade the traction on my F250, it is currently stuck in the snow outside my house. It is a 4x4 crew cab with good tires. It is my daily driver, I will own this truck for at least 10 years (crashes notwithstanding) I also use it as the family hunting/fishing rig. It goes into the forestry area, with icy logging roads and smaller oil leases. It will not be used for mud bogging or rock crawling. Based on your own experiences what would you recommend for this beast? Thank you in advance, all knowledgeable replies greatly appreciated.
Search is your friend. If ya want limited slip get a tru trac posi, will not wear out and is easier to drive in snow/ice than locker. If ya want a locker & have the cash get a selectable locker, arb is good. If you're trying to be thrifty get a powertrax lunchbox locker. Easy to install yourself but take a little getting used to in slick conditions.
The sterling 10.5 had very few options. Most common are the Detroit tru-trac for a lsd or the arb air lockers for a full locker. Ox might make one but Iam not 100% on that.
Some have tried the 11+ e locker but need to upgrade the axle shafts to 37(?) Spline which I believe is easier on the 05-07. But I haven't seen anyone that was definitively successful without a huge amount of problems.
Sent from my Galaxy using IB AutoGroup
It sounds like what may be needed in this situation is a good set of tire chains.
Sent from my HTC ONE using IB AutoGroup
(sitting on the frame or axles, and tires not touching solid ground) all the lockers and limited slip diffs in the world won't help. These type of traction aids only help as long as your tires have traction. And if you do install lockers of some kind, I would recommend a selectable type, not the auto lockers.
In certain icy conditions, I have driven right past guys with auto lockers with open diffs. But then, all this is just my opinions, and don't account for much in some body else's situations. Good luck in what ever you do.
For the rear axle, you could get the Ford e-locker on the '11+ models or get an ARB ($$$). I have a '12 with the rear locker. Very nice that you can select it. However, without a heavy load or weight in the back, it is useless. Tires are key. Last week I got mine completely stuck in an uphill, snowy, icy parking lot...ended up being basically high-centered. In 4-Low with the rear diff locked, I couldn't go anywhere. I am running 10-ply Nokian Hakkapeliitta LT2 studded snows - about the best you can get for this truck - and not good enough. I needed chains; it sounds like you might be wise to invest in a set as well. Standard 4x4 without a locker is adequate; a locker is primarily beneficial in an off-road environment...not in snow and ice. Basically, if you are driving on ice, locking your axle just means you are spinning both tires on ice. When traction is about equal under each rear wheel, a locker will not help.
As for a front locker being dangerous, not, it really isn't. You only select it when needed. Of course you can't turn well, if at all, with it engaged. However, you can't turn to well with the back one engaged either.
Interesting points about tires. I have Toyo M-55 265 70 r17 (I think that's close) about 60% tread left. I got it out today with some effort as the wheels had formed melt ruts and there were many other ruts to jump through. I am concerned about traction as I have owned 2 Explorers and 2 AWD Aerostars and they are both better in street snow/ice than this truck is empty. I know it is designed to haul a load and will fare better with some back there. I have chains for another vehicle and no you can't beat them for traction, they are just such a pain to put on. One reason I was thinking locker is a result of hunting with my buddy last season who has a 2013 F150 Ecoboost with the selectable rear locker and what a difference it made out there and his tires were really aggressive. My RV spun out on an icy hill and he managed to haul it out of the ditch and up a steep hill to level ground, I was tempted to buy one.
4WD systems only can provide power to the tires; but it is the tires and weight upon each tire which actually yields the traction. Your F-250 has just as much traction "capability" as your Explorer(s), but of course the Explorer and your van have better weight distribution over the tires vs the unloaded truck. Locker is nice, but put 1500lbs in the back of your truck and see if it isn't as good as your other Fords.
All I can tell you is that I use a BFG TA K/O in 285/60R17E. I have a factory LS. I don't get stuck in the snow. Drifts get very deep around here. They do not stop me.
My only concern is an ice/freezing rain scenario, where pretty much no one gets traction.
I don't know the Toyo M-55, but I would look for a tire that has the snowflake/mountain symbol, which means it is rated for extreme snow.
