tank select and other wiring issues
wiring issues
Yes it's fuel injected. The switch is good. I did some more troubleshooting today. I jumpered from the battery hot to the plug off the switch and with the engine and key off I could hear the rear tank run and the front didn't. I also drove it with the switch unplugged, it acted like it was running out of fuel but kept going. The other weird wiring thing I didn't get to describing cause my keyboard quit working is in the starting circuit. The red w/ blu stripe wire coming from the clutch safety switch had a wire spliced to it. I cut it and it wouldn't crank so I followed the spliced on wire through the firewall and back along the frame to the vicinity of the hi-press fuel pump where it was crimped to a red w/blu stripe wire that goes into the wiring harness heading toward the engine compartment.
When I bought my 1990 truck, the previous owner had the front tank hotwired. The rear tank did not work.
I found that the plastic connector in the switch was getting hot and melted the connector.
When that happened, it would loose power to the pump.
I repaired the wiring so both tanks work. But the connector still gets hot and has melted the connector I put in. I am now looking for a new part instead of a used part.
It sounds to me like you might have the same problem.
sward0318
12-19-2018 09:57 PM
jazz1
08-24-2011 05:03 PM
amstone
04-17-2009 01:26 PM
