Spring Towers thru-mounted to engine mounts??
On my 79 f150, I am trying to replace my spring towers as one is pretty rusty. However, upon closer inspection, The bolts that hold it to the frame go through the frame (which is boxed here) and through a front motor mount. The truck has a 460 big block. How should I go about removing the towers?
Can i put a jack under the engine to hold it up while I undo the bolts and install the new towers?
