Issues with my 59 passenger door not closing correctly.
Old 01-09-2014, 04:45 PM
Vsanzbajo's Avatar
Vsanzbajo
Vsanzbajo is offline
I am having issues with my 1959 not closing correctly. My passenger does not close properly half of the time. You can just close it but it does not stay closed. I got a door latch and the new one is doing the same. Do these latches need any adjustments?
Any ideas on what is happening?
Thanks
Old 01-09-2014, 11:15 PM
SuperDuty93's Avatar
SuperDuty93
SuperDuty93 is offline
Thanks
Hmm is there a little spring in the part that goes on the cab? I believe there is a spring that helps keep the pin in the toothed part that's on the door. id check that first. I can go look at mine tomorrow if need be
Old 01-09-2014, 11:32 PM
Vsanzbajo's Avatar
Vsanzbajo
The truck is at the mechanic right now. If it is missing where could I get the spring?
Old 01-09-2014, 11:39 PM
SuperDuty93
That idk... Ill see if I have an extra somehwere
Old 01-09-2014, 11:47 PM
Vsanzbajo's Avatar
Vsanzbajo
Thanks, SuperDuty93
Old 01-09-2014, 11:57 PM
SuperDuty93
Thanks, SuperDuty93
No prob!
Old 01-10-2014, 09:07 AM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
It is the wisest money you can spend on your truck!
http://www.ebay.com/itm/1959-FORD-TRUCK-SHOP-MANUAL-ORIGINAL-TRUCK-SERVICE-BOOK-/281242853413?pt=Motors_Manuals_Literature&hash=item417b616025&vxp=mtrGood luck in your quest!
Old 01-10-2014, 03:44 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Look at the pic, notice the 22058 shim. Is it present or not? The parts catalog says AR = As Required, so you may need more than one to get the striker aligned properly.
Notice the 22040 insert has teeth, they wear down, so when this occurs, the wheel on the door latch won't catch properly.
Where's the spring? No see um. If there is one, it will be made as part of the striker plate, so it cannot be replaced.
1961/66 uses a different striker that has a nylon insert w/a coil spring behind it. Neither the nylon insert nor the spring can be replaced, as they're made as part of the striker.
Old 01-10-2014, 04:16 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Did ya just put in new door weather striping by chance?
Old 01-10-2014, 04:27 PM
Vsanzbajo's Avatar
Vsanzbajo
No, I do not think so. Bought the truck 1 month ago and it was like that.
Old 01-10-2014, 04:37 PM
arctic y block
And ya have adjusted the striker and like that and it don't seem to help?
Then ya you should prolly look into one of the fail safe aftermarket assembly's.
Don't want the little woman falling out.
Than maybe ya do. IDK.
Old 01-11-2014, 09:44 AM
chetspencer's Avatar
chetspencer
chetspencer is offline
Would you know of a vendor, or are your referring to chopping out the old and weld in the new type of setup?
Old 01-11-2014, 12:40 PM
spurredon's Avatar
spurredon
spurredon is offline
Ch**y uses this style for a positive closure.Name:  hD840ACAC.jpg
Old 01-11-2014, 12:45 PM
egg collector's Avatar
egg collector
egg collector is offline
This is on page 73 of the redneck quick fix hand book.
Old 01-11-2014, 04:24 PM
chetspencer
Originally Posted by spurredon
Ch**y uses this style for a positive closure.Attachment 88553
I bet that chebby's got the same red neck door handle as I do.
Actually I'm pretty sure a few of you guys have come across my vice grip solution sometime in your past.
bigcrunch
10-16-2015 07:39 AM
Ford1948F3
07-11-2014 07:23 AM
Bushwhacker
Garage & Workshop
01-16-2005 11:12 PM
RickW
02-21-2000 10:29 PM
Quick Reply: Issues with my 59 passenger door not closing correctly.
