Missouri Chapter Join Chapter , Leader:77&79F250
Good Weather
Old 01-07-2014, 03:16 PM
boonslick's Avatar
boonslick
boonslick is offline
Good Weather
Hello and good afternoon Missourians!
Beginning Friday we have 7 straight days of 40's high and 30's overnight.
Now we can get some work done on the projects.
Enjoy the weather.
Boon
Old 01-07-2014, 11:17 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,290 Likes on 2,446 Posts
Stay warm and enjoy the opportunity to get on them projects.
Old 01-08-2014, 03:56 AM
boonslick's Avatar
boonslick
Projects
Hello Rich.
Yes I must get on with the work on the 87 as I am so far behind but this is on me as I procrastinated.
However, I am waiting on some fasteners from Summit.
Moreover, I need to find a stud and nut for my valve cover. Perhaps you know the size? I will probably go to the boneyard for this.
You take care and Godspeed!
Boon
Old 01-08-2014, 06:18 AM
77&79F250's Avatar
77&79F250
Any thing related to a 1980 or newer definitively not, 1979 and older definitively maybe. Shoot that, Alan's way.
Old 01-08-2014, 09:27 PM
PRIMERED79 SHORT BED's Avatar
PRIMERED79 SHORT BED is online now
Good cause i now have a leaky radiator to get fixed.
Stupid -8 degree weather.
Old 01-08-2014, 10:19 PM
77&79F250's Avatar
77&79F250
Bummer Greg.....
Old 01-11-2014, 07:16 PM
Well i thought i had a leaky radiator.
Took her for a spin today and nothing?
What gives? the other day when we had that very cold morning, the whole engine bay was covered in coolant, or so i thought.
Now its acting like its fine..... Crazy.
Old 01-12-2014, 03:13 AM
77&79F250's Avatar
77&79F250
Maybe your cap somehow let a big air bubble and some coolant get out and the fan and wind spread is all over?
Old 01-12-2014, 10:12 AM
I was wondering if my upper hose was leaking again.
For some stupid reason, that thing from time to time will leak.
But with the amount of coolant everywhere, I thought for sure it was the radiator.
I'll keep an eye on it and see, i found out yesterday Lebanon has a radiator shop, so if all else fails i will pay him a visit.
Old 01-12-2014, 10:16 AM
77&79F250's Avatar
77&79F250
Good deal to locate a shop that can and will repair. Pass on the local....
Old 01-22-2014, 09:06 PM
Found what my issues is, this video demonstrates what its did.
Anybody ever try these clamps?
Old 01-22-2014, 09:34 PM
earthquake68's Avatar
earthquake68
earthquake68 is offline
Nope. I think this demonstration over exaggerates the issue. Properly maintained cooling systems have little trouble leaking. There's less clamping power at 0 degrees, but how much pressure is in the system when it's 0 degrees? ...that's right. Zero PSI. As the coolant heats up, so does the metal and the hoses, so the clamps become effective again. There's a VERY narrow window when pressure could climb faster than temperature does. This is where proper maintenance comes in. A coolant recovery system will "top off" the radiator for you if you keep it in good shape with enough coolant in it.
In any case, I'm glad you found your problem. I've never used, ...or needed to use those types of clamps.
Old 01-23-2014, 09:24 PM
For some reason my hose clamps keep loosing up.
So i bought a new cap, upper hose, and clamps, hopefully this stops the cold weather leaks.
dlibson
Minnesota Chapter
667
11-02-2015 09:30 AM
dogg16
Bronco II
07-03-2007 11:34 AM
TUFFY
Missouri Chapter
03-29-2005 09:33 PM
Vampiro
07-16-2002 12:53 AM
Quick Reply: Good Weather
