O.T propane tank
I would check with a propane house on whether the regulator on the new tank, and/or the one on the old tank, were suitable. The one on the new tank likely flows a lot more than a BarBQ grille regulator, the one on the old tank may not be rated to the pressure of the new tank. I'd wager a two-stage reg is needed.
I used the bar-b-q tank to run my forklift. I was using my forklift in my shop on a Sunday, the place I go to fill my tanks is closed on Sunday. I was in the middle of a lift when it died. I thought my second tank was filled but when I went to get it I found it was also empty. I grabbed the barb-b-q tank and found the connection was completely different. Took a ride to farm supply store, bought fittings I needed and got the forklift running again. I keep the fittings in my tool box for the next time I forget to fill my tanks. I can exchange my barb-b-q tanks almost anywhere, not so with the bigger forklift tanks.
PAWZ Guitar Company
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
58
10-18-2015 08:11 AM
mmmPowerStroke
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-19-2006 09:28 PM
