Should the carrier bearing move vertically?
I was under the truck last night changing out rear sway bar bushings, and happened to grab the drive shift near the carrier bearing for leverage on the creaper. And I was rather surprised to find that the shaft moved rather freely up and down in the carrier bearing.
Is this normal? I figured it would be held in a much tighter arrangement
