ignition issues on a 1976 302 in my 1954 f100
Old 12-28-2013, 02:13 PM
Trues_01's Avatar
Trues_01
Trues_01 is offline
Ok i guess I'll start with the truck has a 302 from a '76 Maverick. It ran good before it was in a flood. I've rebuilt the motor and had it running with the old wiring that was spliced in many different places. But the alt went out and the voltage regulator went out and the coil almost at the same time. I have replaced everything except the distributor. I also ran all new wires to everything. I'm getting fire from the coil to the distributor and the truck will turn over but will not fire up. It doesn't have an ignition module just goes from the solenoid to the coil I'm lost at this point so any suggestions or wiring diagrams would be most helpful at this point.
Old 12-28-2013, 02:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
So you are running points? And you are running 12v negative ground?
If you have a 4-post solenoid, one of the small posts should be labeled "I". That one goes directly to the coil (+) terminal. In addition there has to be a wire from the IGN terminal on the ignition switch, that usually runs thru a ballast resistor to the (+) terminal on the coil. If your coil is made with an internal resistor, then you don't need an external ballast resistor, and the wire from the "I" terminal is useless.
Old 12-28-2013, 02:32 PM
Trues_01's Avatar
Trues_01
Trues_01 is offline
The coil that i put in is an MSD Blaster 2F and I don't have the ballast resistor on it just straight wire. so I'll see if i can find one thank you for your help. also how do i post pics on here that could possibly show what im doing for further help
Old 12-28-2013, 02:39 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C9OZ-12250-A .. Resistor Wire-Ignition Coil-Marked: C9OB-12250-A (Motorcraft DY-85).
60" long / Color coded pink / 1.30-1.40 ohms resistance / #16 gauge wire.
1969/73 Fairlane/Torino/Mustang/Cougar / 1971/76 Maverick/Comet.
DuraSpark Electronic Ignition introduced in 1974, but not all vehicles came with it until 1976.
Old 12-28-2013, 02:45 PM
Trues_01's Avatar
Trues_01
Trues_01 is offline
Also the distrutor has one wire that was connected to the coil is it supposed to be on the positive or negative side? my brother pulled it of and i need to make sure its put back in the right spot. The wiring diagram that i have says it goes on the negative side with the tac wire
Old 12-28-2013, 03:54 PM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
You are correct, negative side. If you have spark from the coil to the distributor but not to the plugs? Do you have the rotor in the distributor?
Old 12-28-2013, 04:57 PM
Trues_01's Avatar
Trues_01
Trues_01 is offline
Yes sir cap and rotor are new.
Old 12-28-2013, 06:29 PM
Rimrock F1's Avatar
Rimrock F1
How did you check for spark at plug?
Old 12-28-2013, 06:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You need a ballast resistor with that coil
Old 01-01-2014, 04:43 PM
Trues_01's Avatar
Trues_01
Trues_01 is offline
Hello i talked to you the other day about my ignition on my '54 f100. i got the ballast resistor and needed to know what post on my switch. there is a battery post an acc post and the ignition post. also should there be a wire from the "I" side of the solenoid to the (+) of the coil in addition to the ballast wire.
Old 01-01-2014, 04:57 PM
seaves46's Avatar
seaves46
seaves46 is offline
Ballast resistor needs to be in the coil supply wire between the ign switch and the coil .
fxef79
04-24-2019 11:10 PM
ved0303
01-02-2015 11:07 PM
fordguy76
11-14-2011 09:36 AM
76blue
10-12-2009 01:08 PM
250-highboy-76
15
05-11-2006 05:24 PM
Quick Reply: ignition issues on a 1976 302 in my 1954 f100
