79 Bronco heater blower wiring question
I'm in the middle of adding AC to a truck that didnt have it. The truck has been re-wired, so it's not just stock plug 'n play. From the junk yard, I grabbed all the wiring pigtails that I could and I THINK I got it all. But I'm having a little confusion with the resistor wiring.
I've been following the wiring diagrams posted up at Fordification.
Here's a picture of what I have:
So where the confusion lies is with that unhooked red/black wire. From the diagrams I found, it looks like it AND the other red/black behind it should connect to the orange heater wire, which is what I've done. HOWEVER, when I do that the motor still runs very, very slowly with everything in the "Off," position. With that single red/black wire pulled like it is in the picture, everything SEEMS to work normally...but I havent quite gotten to wiring up the 3 wires that come out of the back of the control slider yet, so maybe that will clear things up?
Can someone point out what I'm missing?
I've found reference to relays for the blower in a few posts, but I didnt see any in the junk yard and I dont see one referenced in the diagram I posted a link to.
Ok, maybe I looked at the diagram a little too quickly. I thought that c-606 was a "either/or" thing, but it's just a plain connector correct?
If that's so, then what you are saying is the power 181 orange wire goes over to the far right, through the dash selector. The fan circuit gets power in any position except position #1, and the A/C clutch gets power only in position #3.
So I would find the proper red/black wire coming from the dash switch and see if it has power on it with the dash switch in the off position. In off this should kill the whole thing correct? I would get a voltmeter or testlight and check it out.
parr4
16
04-14-2017 08:40 AM
psychlopath
12-29-2013 09:17 AM
The67Beast
12-16-2012 04:16 PM
