early 03 6.0 problems 190,000 miles
Old 12-25-2013, 02:57 PM
USMCveteran's Avatar
USMCveteran
USMCveteran is offline
I know its been a while sense my last post. Been really busy with work and the holidays. Here is what has been done to truck and scan gauge readings below.
Both batteries replaced. New starter and alternator. All new filters fuel, oil, and transmission. New fuel with filter change. Tank had to be dropped due to fuel pick up being in a million pieces. New oil with oil filter change 5w40. Crankshaft sensor was replaced. New icp sensor with new pigtail
KOEO RUNNING
VLT. 12.3. 13.9
FVP 11.5 - 12.5. 13.5
FPW. 0. 1450
RPM. 0. 650. (1262 with peddle to floor)
FPR 0. 0
MAP. 14.3. 14.0
GPT. 0. 0
CYC 1. 1
VFD. 0. 30
MFD. 0. 25.6
IPD. 14.4. 29.5
ICV. 1.24. 1.24
IPR. 14.8. 31.6
SYC. 0. 1
FLP. 0. 0
FMP. 47.5. 47.5
ICP 838. 765 - 813 (775 when peddle is to the floored)
HPR 0. 12.8
TFC. 0. 0.34
anyone have any ideas. Rpm and icp are kinda confusing me... any help would greatly be appreciated
Old 12-25-2013, 03:01 PM
USMCveteran
One last thing that i forgot. Truck starts in like 5-7 sec. However once it turns over I have to hold it a lil while longer for it catch. Once it catches it acts like it wants to die then it comes back to life. Does this twice before it smoothes out and runs.
Old 12-25-2013, 03:51 PM
Fal-308-Win's Avatar
Fal-308-Win
Fal-308-Win is offline
Icp has me confused also. When posting numbers do it just like this.
Warm engine up to 190* ECT, truck in park or neutral, all accessories off, post 3 sets of numbers one at KOEO, two at low idle, third at high idle (2500 RPM)
post icp,icp volts, ipr%, and FICM main power
Old 12-25-2013, 04:13 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Given it won't rev over 1200 rpm I would suspect EGR stuck open or throttle plate stuck closed.
Fuel pressure would be nice to know
Josh
Old 12-25-2013, 04:47 PM
USMCveteran
Everything is off. The truck was warm. I will let it run a lil longer this evening and post numbers again. Truck has an egr delete with a plate. I didn't think about the throttle plate. One other thing I also forgot early. If you give it gas once you let off you have to let off and then tap the peddle a few times to keep it from dieing
Old 12-25-2013, 07:22 PM
mustang_309's Avatar
mustang_309
mustang_309 is offline
ICPV @ 1.24 at KOEO is a problem, and IPR @ 31 while idling isnt good either. If it isnt the EGR im wondering if the HPOP isnt failing.
Old 12-25-2013, 07:31 PM
Fal-308-Win
Yea, I'm thinking get the HPOP system confirmed or condemned, and then move on.
Old 12-25-2013, 07:50 PM
Bullitt390's Avatar
Bullitt390
Is engine able to run long enough to hit 185+ ECT?
Until then the idle IPR% is meaningless.
Josh
Old 12-25-2013, 08:07 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
hat do you have for V-Ref??
Old 12-25-2013, 08:20 PM
USMCveteran
It will run until it runs out of fuel if you let it. I will let it run a lil bit to warm up and then post new numbers. I was hoping it wasn't the hpop. I believe its the original though. Now hopefully I can finallybget some one in my chapter to answer me so I can get some help with the hpop.
Old 12-26-2013, 07:09 AM
USMCveteran
I let it warm up and there wasn't much difference in the numbers. Could it possibly be bad or sticky injectors?
Old 12-26-2013, 07:20 AM
mustang_309
You need to let it warm up to 185 to 190* and then check the IPR%
Old 12-26-2013, 07:54 AM
USMCveteran
It ran for over an hour so it was good and warmed up. Let it run while tried to look up the next parts need that broke. Maybe you guys can help need the rubber hose that goes from the intake manifold to the hard plastic housing just before the turbo. Also need that hard plastic housing. Hose was dry rioted and housing is cracked and broken on bottom where hose connects
Old 12-26-2013, 01:21 PM
BLADE35's Avatar
BLADE35
It does the map sensor by the AC box
Your ICP VOLTS is causing the problem
So ICP Volts never changes
Old 12-26-2013, 01:23 PM
BLADE35's Avatar
BLADE35
That's why I'm asking about the REFERENCE VOLTAGE
Quick Reply: early 03 6.0 problems 190,000 miles
