1979 F150 am radio ...Looking for Am / FM Radio conversion
Depends on what you want to spend, and what you do or don't want to do to your truck.
I wanted it to look bone stock, and retain the No battery drain function that the original radio had, so I took my radio out and took it to a local guy who wired an auxilary input jack into it. When you plug something into the jack it supercedes the Antenna input and your I-pod or whatever then plays through your still stock radio. My I-pod plays local radio channels, so total cost $20
Kicker makes a small "hidden" unit that you can wire to the speakers and that plays and controls an I-pod The unit charges, and controls the I-pod, and you basically then ignore your stock radio. Cost $200 plus an I-pod
Several guys have made the swap / conversion to the DIN style head units with just a little Fabbing. Cost is dependent on the system you install.
LOL! NOT TRUE! Now, the old speaker may be in bad shape and not sound good, but as far as a speaker is concerned, it doesn't matter whether it's getting a signal from AM radio, 8 track or Sirius, it's all the same.
I bought one from these guys and thought it was the best bang for the buck.Vintage Car Radio .com
It was an exact fit but I don't remember the details of the wiring so I assume there was no issues there either..
I left my stock radio in place . I hate to cut up my dash . I got a CB mounting bracket and mounted an aftermarket radio under the dash like you would mount a CB radio . Now I have a modern radio/cd/Mp3 player etc. and no chopped up dash . I did something similar in my 65 years ago . Just a thought !
I bought one from these guys and thought it was the best bang for the buck.Vintage Car Radio .com It was an exact fit but I don't remember the details of the wiring so I assume there was no issues there either..
am/fm tuner
Have you looked at retrosound.com They make some awesone vintage looking am/fm tuners that you dont have to cut your dash for at all they fit i n the stock harness i just picked one up for my 1975 ford f250. They have usb inputs, bluetooth, handsfree calling the whole works built in crossover if you wan't to add subs later. a little pricey at around 299.00 but you don't have to cut your dash and you can keep the stock look
LMC has stock "looking " units . I am too cheep for that . That is why I mounted a modern radio under the dash with a CB mount . Easy to remove , no chopping the dash . When I was into VW's years ago , there was a company , you could buy a "hidden " stereo . It went in the glove box . Sure they are still around . Many options . Some cheep , many not .
