1979 F150 am radio ...Looking for Am / FM Radio conversion
1979 F150 with a am radio ...Looking for Am / FM Radio conversion
Any one able to assist? See a few on eBay for $159 but I take it I have to cut wires... Thanks guys |
Depends on what you want to spend, and what you do or don't want to do to your truck.
I wanted it to look bone stock, and retain the No battery drain function that the original radio had, so I took my radio out and took it to a local guy who wired an auxilary input jack into it. When you plug something into the jack it supercedes the Antenna input and your I-pod or whatever then plays through your still stock radio. My I-pod plays local radio channels, so total cost $20 Kicker makes a small "hidden" unit that you can wire to the speakers and that plays and controls an I-pod The unit charges, and controls the I-pod, and you basically then ignore your stock radio. Cost $200 plus an I-pod Several guys have made the swap / conversion to the DIN style head units with just a little Fabbing. Cost is dependent on the system you install. |
i had pulled my radio/defrost bracket out and made a new one to hold a new style radio , any sheet metal shop should be able to do that if its the direction you would want to go
Originally Posted by RunninD
(Post 13872893)
Originally Posted by GOLFER1ESS
(Post 13873149)
I have heard that the stock AM speaker will not play fm music... is this true?
I bought one from these guys and thought it was the best bang for the buck.Vintage Car Radio .com
It was an exact fit but I don't remember the details of the wiring so I assume there was no issues there either.. |
I left my stock radio in place . I hate to cut up my dash . I got a CB mounting bracket and mounted an aftermarket radio under the dash like you would mount a CB radio . Now I have a modern radio/cd/Mp3 player etc. and no chopped up dash . I did something similar in my 65 years ago . Just a thought !
Originally Posted by miketaheny
(Post 13874013)
I bought one from these guys and thought it was the best bang for the buck.Vintage Car Radio .com It was an exact fit but I don't remember the details of the wiring so I assume there was no issues there either..
Golfer, the AM will play the FM stations it just doesn't receive them due to the wrong frequency. if you bypass the input (the antenna) and use your I-pod like I did with mine it plays everything that it gets fed. The signal is decoded by the I-pod so there is no issue.
am/fm tuner
Have you looked at retrosound.com They make some awesone vintage looking am/fm tuners that you dont have to cut your dash for at all they fit i n the stock harness i just picked one up for my 1975 ford f250. They have usb inputs, bluetooth, handsfree calling the whole works built in crossover if you wan't to add subs later. a little pricey at around 299.00 but you don't have to cut your dash and you can keep the stock look
Still looking for a stock looking AM/FM Unit i can wire in....
Look for a stock on on eBay???
LMC sells some
Originally Posted by Dave145
(Post 13900849)
Not seeing any on eBay ...
