Wiring / Emission / Computer Delete
Old 12-13-2013, 07:20 PM
KsCop's Avatar
KsCop
KsCop is offline
Bear with me, this could be a long post.
I have a previous thread regarding a carburetor question and it started to evolve into a discussion on cleaning up the wiring and deleting some emissions.
To that end, I though I'd start a separate post.
After the carb and ignition change (DUI) I'd like to clean up the engine compartment and simplify things a bit. I've been doing some digging around and managed to figure a few things out, but still have some questions.
I followed the wire harness to the right firewall and think I located the MAP sensor. In that harness is also a wire that goes to the starter solenoid, so I'll need to get that separate from the rest, yes? (and the MAP sensor can go, correct?)
There are a few things that I'm not sure what they are or do; since a picture is worth a thousand words, here we go:
What is this and can it go away (looks like some relays or solenoids under the cover);
This (and a black one) look like vacuum lines going to the smog pump valve. If the SMOG system is deleted, do these get capped, or do they route to the above solenoids (if that is what they are)
What is this orange (pink) line coming off the carburetor?
What about this canister. Stay or go?
It looks like there is some sort of valve or sensor on the line coming from the above canister to the carb. What is it and after the computer is gone, can it go away (or should it)
Bottom line; what can go and what needs to stay??
What about the EGR? Computer controlled or no?
I suppose since I'm getting rid of the computer, anything controlled by the computer might as well go. What all is that???
And this conversion was supposed to be easy. Well, I guess the conversion is but the cleanup is confusing the heck out of me..
Old 12-13-2013, 07:49 PM
oneowner83's Avatar
oneowner83
oneowner83 is offline
The vapor cannister is bringing fuel vapors from the tank and sending them to the carb to burn up, rather than send them into the air.
Old 12-13-2013, 07:58 PM
KsCop's Avatar
KsCop
KsCop is offline
I did manage to do some more research as related to this canister. I know what it is, but wasn't sure how it worked.
The device in the picture that is inline with the canister as it enters the carb is the canister purge solenoid. It is computer controlled, so if I understand this correctly, the EVAP system won't work after the computer is pulled out and might as well go away.
Ditto for the EGR and SMOG pump from what I can tell.
If I'm on the right track, it looks like remove items, plug holes and vacuum lines / ports as needed. Open up wire harness and keep some wires and pull the rest. The first picture I posted appears to be a bank of vacuum control solenoids that are also under computer control - so that can go as well.
Am I on the right track? Anything I'm missing?
Old 12-13-2013, 08:36 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
Keep doing research and find out what everything does. If you did verify that the computer controls the purge solenoid, how are you going to deal with that? If you do not mind a fuel smell coming from the engine compartment, then ok you can get rid of all that and the canister. If you do mind a fuel smell, I think I would leave some of it. I am not totally up on the purge system, but you might just be able to activate the solenoid anytime the key is in run. The first thing I would do is experiment and hot wire the solenoid to the battery by just touching the wires, and see how it affects how the engine runs, and then go from there.
That orange line going to the carb looks like the fresh air line going to the choke system. That line will run filter air down to the exhaust manifold where it's warmed up and then sucked into the carb choke housing to make the choke work. That's the line you were wondering about re-routing.
All this stuff originally had a purpose, so there will be some things that are affected if you get rid of it.
Old 12-13-2013, 08:47 PM
KsCop's Avatar
KsCop
KsCop is offline
Since I don't have the cats, I don't see the purpose of the smog pump anymore. In terms of the EVAP canister, I know that others have pulled the computer, so I'm wondering how they dealt with the purge solenoid (or am I off track and that isn't controlled by the computer?)
Bottom line, I guess I need to know what emission stuff is controlled by the computer..
Old 12-14-2013, 08:59 AM
LARIAT 85's Avatar
LARIAT 85
LARIAT 85 is offline
1. - The map sensor is located on the passenger's side firewall and can removed. The wire that connects to the starter solenoid can be removed as well. On my truck that was a thick yellow wire with an eyelet and it was used to power the computer.
2. - I would start be removing the engine computer and the wiring that goes with it first. It is all part of one large wire harness. The only things that you will need from all that mess is the engine temperature sending unit wire, the oil sending unit wire, and the tachometer. It will be much easier and neater to just wire these back in from scratch than to to try to sort it out. (Once you start to remove the computer and the wire harness, you will see what I mean; some of those splices were SCARY.) Once you have dealt with that, anything left unplugged can be removed.
3. - Not sure what the second picture is.
4. - Like Franklin said, the orange tube is the fresh air connection from the carburetor to the choke stove. Leave this in place.
5. - Leave the charcoal canister in place for now. It is part of the evaporative emissions (EVAP) and it's purpose is to store gas fumes from the gas tank and the carburetor fuel bowl. With the computer gone and canister purge solenoid now useless (the solenoid shown in your last picture), the vapors can't be purged back into the engine to be burned, but that can easily be fixed later by adding a vacuum operated canister purge valve and ported vacuum switch. This system works much like a PCV valve and doesn't rob any horsepower to operate. Like Franklin said, this will keep your truck from smelling like a gas station all the time.
Old 12-14-2013, 03:02 PM
KsCop's Avatar
KsCop
KsCop is offline
Sounds like a plan then. Any idea on part numbers or where I can get the vacuum solenoid and ported switch?
Old 12-14-2013, 03:39 PM
KsCop's Avatar
KsCop
KsCop is offline
Would this be the vacuum valve that would work? Where do I pull the ported vacuum to operated this?
aaron.gwin
52
07-10-2014 07:38 PM
Seth_84F250
25
12-17-2013 08:22 PM
gotjeepzj
08-16-2009 08:05 AM
rostena
137
09-01-2008 07:20 PM
Lead Head
13
12-23-2007 05:41 PM
Quick Reply: Wiring / Emission / Computer Delete
