2001 F250 Heater problems
Hi, the heater in my truck isn't working correctly, one of the 2 hoses that go into the cab goes lukewarm after about 15 mins, the other hose stays cold, I noticed my coolant is at the minimum point, could that be causing it ? I can feel warm air if I turn off the blower, and then turn it on after a few more minutes, and it will blow hot air for about 5 seconds, before the cold comes in again. Any ideas ? I replaced the thermostat last year, do you think the low coolant is the reason ?
Thanks in advance.
Thanks in advance.
Hi, I filled up the coolant, and still same problem, I noticed that if i put the blower on the lowest setting I do feel warm air, but if I set the fan on 2 or 3 then it's only cool air I get. I tested the pipes again and one is a lot warmer than the other, could it be a blocked heater core, and is there an easy remedy for that ?
Thanks
Steve
Thanks
Steve
Mr/bill
11-12-2012 07:57 AM
