exhaust brake on a 460
Thanks BLKF250HD for the feedback. But it does not really answer my question. A lot of times you want less engine braking then second gear allows, as in third, the engine braking is not really sufficient. I assume that the torque converter is not locked up in third gear with overdrive disengaged. Please correct me if I`m wrong, but going downhill in third only feels like partial engine braking is taking place. I live in the mountains, and just like the idea of using free exhaust back pressure to slow me down, then to have it all be turned into heat(equals wear).
Straight from Jacobs Vehicle Systems:
FAQ6:
Do you have any engine brakes or exhaust brakes for Gasoline engines?
ANSWER:
Because of the low back pressure limits of gasoline engines, the performance of a gasoline exhaust brake would not be substantial. Because the air intake in a gasoline engine is throttled and the compression ratio is much lower than in a diesel, the performance of a gasoline engine brake would also be insignificant. Because of this we do not offer any retarders for gasoline engines. However, Jacobs is actively seeking the commercialization of its Variable Valve Actuation System (VVA) for gasoline engines. The benefits of increased fuel economy (throttling with intake valves instead of a butterfly), miller cycle valve timing, EGR, and even compression release braking are just some of the reasons VVA would be an attractive option for gasoline engines in the light truck and passenger car markets. For more information about Jacobs VVA, click here.
Also in the same section, which applies to gas engines as well (hydraulic lifters):
".......The primary concern with putting a retarder on these engines (7.3 Powerstroke and T444E) is their use of hydraulic lifters. Most engines with hydraulic lifters have fairly low exhaust back pressure limits so the performance of an exhaust brake would not be substantial. More importantly the use of an exhaust brake on an engine with hydraulic lifters can cause engine damage. The problem is that the increased back pressure resulting from the operation of the exhaust brake will cause some degree of valve float. This valve float can cause the hydraulic lifter to re-set with the valve still open (not seated). This phenomenon is known as lifter jacking. Lifter jacking could also result if a traditional engine brake were used on these engines. The results of lifter jacking can be anything from low positive power (because the valves stay open) to engine damage caused by valve to piston contact."
Sounds like it would be a waste of time and money to try to rig something up.
FAQ6:
ANSWER:
This is why I joined this forum!
Hey BLKF250HD, now we are talking. OK, I get it, actually it makes a lot of sense, but I wanted to find out, and you pulled this article out of your hat!Awesome! This is why I joined this forum. Every body (well most everybody) has some thing to give. So thank you! I sent an e-mail to the Banks guys, and now I feel somewhat embarrassed. Oh well, nothing wrong with asking. Thanks again. Can now go to bed in peace.
FAQ6:
ANSWER:
FAQ6:
ANSWER:
