carter yf and yfa help and Facts
hello , as formentioned in my many threads
I have a 1985 ford F-150 4x2 np 435 , 4.9l inline 6
duraspark ii conversion
Carter yf conversion ( was carter yfafeedback ,then just a worn out yfa )
now here I am with trying to get the bugs out of this whole system ,
what are the adjustments for a carter yf 1974 carburetor brand new?
cause I have been trying to get a miss out of this engine since I got the darn thing have had little luck
Have you done a compression check? Vacuum leak check? Ignition component condition check? Heat riser/air cleaner damper/choke tube operation check? These things will contribute to a misfire more often than a carb adjustment, and all the adjusting in the world won't help if the basics aren't squared away first ~Bill
1. vacuum leak check none to be found
vacuum is 18-19hg and steady
2. compression no check don't have a gauge
ignition should be check ok it is all new and spark where and when it is suppose to
unles its the module ?
4. no damper heated air inlet to speak of ( previous owner butcher things) the air breather part any way , but the exhaust / intake spring damper heat riser thing is working
choke tube works got it working not long ago before winter
xtal_01
12-05-2016 09:53 AM
dakotarider
13
10-27-2012 11:28 PM
ddmack304
10-19-2011 01:29 PM
68 250 Flareside
04-10-2006 09:23 PM
76 F250 4X4
09-20-2004 12:12 AM
