HPOP oil change question
Old 12-08-2013, 02:51 PM
96ExtracabPSD's Avatar
96ExtracabPSD
96ExtracabPSD is offline
I read a bunch of the old debate threads and I agree its not needed when doing an oil change. Not even looking to start that debate! I generally run too far between oil changes and sure enough when cold weather hits I have a problem with the HPOP reservoir draining, will run about 10 seconds and I have to refill the reservoir to get it to restart. Decided I'm going to switch to a full synthetic since I suck at regular maintenance.
Going from either Delo or Rotella (can't remember which one I used), should I drain the HPOP and heads when switching to the synthetic? Not sure if its bad to mix the two, even if its only a couple quarts vs 15.
Old 12-08-2013, 02:58 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
I would fix the issue of loosing the oil out of the HPOP. As for changing the oil in the reservoir, that's really up to you. Since you're switching to synthetic, I believe you'll want to change it pretty early for the first change. So, I would still change the oil in the HPOP reservoir, but I don't think it is necessary other than the thought that you got more of the old oil out.
Old 12-08-2013, 06:01 PM
96ExtracabPSD
Yeah I'm not real sure what I need to fix, and it's only a problem when it's over due for service. I think I'll just change oil normally, and then aim to do it again at a decent interval.
Old 12-08-2013, 08:16 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
To get all the old oil out, you need to pull the motor and take it all apart. There is probably a couple more quarts hanging around it there! LOL Seriously, it says right on the bottle it OK to mix with dino.
Old 12-08-2013, 08:42 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
You said now that its cold your HPOP drains down.....Well when oil gets cold it gets thicker and doesn't drain very good so.....Synthetic will not cure your problem, just make the drain back issue worse.
Have you checked your oil level lately? if these things are low on oil and its real cold they will suck the pan dry before the cold, thick oil drains back to the pan. I've done it many many times here in the frozen north.....It was -25º when I was heading home last nite. mine died twice while warming up at work.
Diesel Rod
Old 12-08-2013, 09:16 PM
96ExtracabPSD
It starts for about 10 seconds, so less of a drain back issue and more of a HPOP supply issue. It's done this for 11 years that I've had it, probably a good reminder for me.
waterboy_fishing
04-13-2013 06:50 PM
goosehunta
10-22-2012 04:01 PM
Canadianpowerstroke
08-27-2012 06:00 PM
mblanken881
11-24-2011 09:36 PM
jjenkins334
02-19-2009 09:23 PM
Quick Reply: HPOP oil change question
