Need Help Wont Start
Old 12-06-2013, 09:36 AM
MrsCopenhagen's Avatar
MrsCopenhagen
MrsCopenhagen is offline
I have an 84 F250 with a 6.9 in her. Yesterday morning I went out to start her cycled the glow plugs once went to do it again and I had smoke coming out of the hood. Shut her off popped the hood and looked around didnt see anything weird. Cycled em again and saw the smoke was coming from wires. Jumped out and saw a wire had been burnt all the way thru. Started it with ether and she fired up fine no smoke. But I didnt have radio or dash lights. Headlights turnsignals and the lights for my guages all worked fine. Shut her down and ran in the store came baxm out wouldnt start with ether dad gave me a pull start she wouldnt start till he put a wire from the battery to the fuel injection pump. Only way she will start now. I need help my dad always drove 6.9s and he has no clue. Glow plugs are only a few months old its not the solenoid. HELP !!
Old 12-06-2013, 09:56 AM
jas88's Avatar
jas88
jas88 is offline
Where are the wires located that you saw the smoke coming from? Passenger side inner fender?
Old 12-06-2013, 10:24 AM
MrsCopenhagen
Yes its the wire that runs the sterio and dash lights. Its the only one that burnt thru
Old 12-06-2013, 01:07 PM
MPoulson's Avatar
MPoulson
MPoulson is offline
So you had a short.
Either the insulation is rotting off some wires in the engine harness or a wire has chafed through somewhere. Or your radio installation was half assed.
You'll have to cut the harness open and trace the burned wire back. It has probably melted through some ajacent wires and shorted them too.
Old 12-06-2013, 08:51 PM
irhunter's Avatar
irhunter
irhunter is offline
I would start by cutting the bad wire and checking for a blown fuse. After replacing any bad fuses, a full report of what has power and what doesn't (e.g., lights, brake lites, radio, heater fan, power to starter...) might help.
It seems you have no power (except jumped power) to the fuel shut-off on the IP.
Roy
Old 12-07-2013, 03:11 PM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
slow down, think, all power flows from, long post at start relay on fender, the long post is the point that every thing hooks to. the relay is not involved in the problem. from this point the main power wire's go thru a fuse able link then to the fuse box, and on to the loads. one wire on this post is the power to the gp relay, this wire is the heaviest load on the truck, a corroded connection, or corroded wire will have resistance, and when it gets hot, resistance increases and so on. next is fire. before fire, we get damaging heat melting stuff that may not even be part of the problem. it may be necessary to replace the harness from a donor truck. all conections must be clean and tight.
Old 12-07-2013, 03:42 PM
irhunter's Avatar
irhunter
irhunter is offline
But, before even thinking of cutting open the harness or replacing the harness, we need to know what circuits are affected.
Roy
Old 12-08-2013, 09:52 AM
MPoulson's Avatar
MPoulson
MPoulson is offline
Since the dash lights and radio are supposed to be on different circuits, I'd say the stereo was hacked.
Old 12-08-2013, 12:37 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
Well, I think the OP is MIA and we're talking to dead air.....
Old 12-08-2013, 10:02 PM
speedwrench72
or mabee he put in the radio,
Old 12-09-2013, 08:02 AM
Chevy_Eater
Old 12-09-2013, 01:14 PM
MrsCopenhagen
I am not a he I'm a she. And we hotwired my glow plugs and fuel injection pump. She started last night and ran like a top. This morning. Crank but no fire.
Old 12-09-2013, 01:29 PM
mknapik's Avatar
mknapik
mknapik is offline
While cranking were you getting smoke out the exhaust
Old 12-09-2013, 01:41 PM
MrsCopenhagen
Im not sure. I wasn't paying attention to that but I dont think so.
Old 12-09-2013, 01:47 PM
irhunter's Avatar
irhunter
irhunter is offline
Oops...I now notice the Mrs. in the screen name.
Last night, you ran 12v. to the IP and glow plug controller, and the truck started using the key like normal. Is that right?
Roy
Quick Reply: Need Help Wont Start
