Replaced glow plugs this week.
Glow plugs should ohm to about 1 ohm each, and yes, you can ohm them through the VC gasket. They will be the outermost two pins on each connector and you'll just measure between them and a good engine ground. Generally if they're bad, they will ohm out open or a much higher reading, but 0.8-1.5 ohms is normal.
AKHunter93
28
11-27-2016 01:01 PM
ryanelwood
07-14-2012 11:01 AM
IDIDieselJohn
05-12-2012 04:54 PM
