1985 F150 4.9 Ignition Conversion / Carb Replacement
I have the feedback carb, etc. on my 85 F150, 4.9l. I'd like to get away from that and go to a duraspark ii. I can find all the parts EXCEPT the wiring harness!
I've called all over town and no one has anything that era in the salvage yards.
SO - What are my options? Are there other, affordable, conversion options to get rid of the feedback carb and computer? Is there another source for the harness and will ANY Duraspark II harness work?
I'm stuck....
(This is why I like my '63 - simple...)
I'm stuck....
I'm looking at the DUI system but haven't used one before.
Do I understand this right? It doesn't use a separate coil?
The system is just the DUI distributor (with one hookup to 12v), Plug Wires and the new non-feedback carb?
Then timing is just set as usual?
That sounds way to simple...
Am I on track or ?
Am I on track or ?
Am I on track or ?
Am I on track or ?
You can adjust the ignition curve with weights and springs.
Some models have vacuum advance too.
Am I on track or ?
Am I on track or ?
You won't get all the benefits from a computer setup, but your fuel economy shouldn't suffer too much to even look back.
Am I on track or ?
Am I on track or ?
The DUI is the best one and the one I would personally go with if I had to go aftermarket. Like the GM HEI, the ignition coil and module are built right into the distributor. They work well and are simple to hook up...just one wire. And like the Duraspark ignition, if you need replacement components in the future, you can get them in any parts house in America; you just have to remember to ask for GM parts.
The downside is they are very expensive, very big, and extremely ugly. They are a GM design, and GM mounted their distributors in the back of the engine while Ford's are right up front, where the distributor will be front and center. They are HUGE, so your stock air cleaner might not fit.
And there is just something not right about opening the hood of a Ford and seeing a big ugly GM distributor right in the front.
I think I've pretty much decided on the DUI conversion. The last question is; what carb to use?
I was thinking of a YFA w/Electric choke. National Carburetor ND1506 seems t fit the bill
Thoughts? This should just bolt on and existing linkages connect?
SO...
DUI Distributor and Plug Wires
Carter YFA W/Electric Choke
Install new carb, install distributor, connect the 12v, connect the plug wires (in the correct order of course), set the timing and away we go...
(anything I'm missing?)
SO...
Pat54632
22
11-04-2016 11:15 AM
