1986 F-250 diesel conversion choices.
I have a 1986 Ford F-250 4x4. The truck has a 460 and 4spd in it. The motor is running on borrowed time and I would like to replace it with a diesel engine. The easiest and most seen swap is the 5.9 Cummins conversion (I even helped my dad drop one in his 1887 F-250) but I would like to try something different. What would be some possible choices? Cat: 3208, 3126 Cummins: 5.9, 8.3, V-8 International: 466 Perkins, John Deere, Detroit........ I know some of these engines would require beefing up the front end. I would just like some input.
The Cat engines would be a really tight squeeze. I have heard about a Detroit 4-72 in a Ford truck, but again, it's a tight squeeze. A Mercedes 6-cyl diesel would make an interesting swap, but you'd have to crank up the boost a bit. Have you considered swapping in a well set up 7.3 Powerstroke? That may be the easiest swap, aside from the Cummins 5.9.
on
The PowerStroke is waaaaaay too much wiring.... It's worse than swapping in an EFI engine.... It's throttle by wire, needs the 94 up diesel instrument cluster(won't run without it, and, it doesn't just need the PSOM), VSS, etc, it's an absolute total nightmare to swap into anything but a truck that had one.
Anything longer than the B5.9 is going to require firewall modifications, and, it'll require beefing the front end a bit on it's own, 1200 LBS or so, while a 460 is about 740(dry.)
I'd just dump in the Cummins, most everything else that's a worthwhile swap(I don't see a 2 stroke Jimmy being a great swap.... Not exactly an efficent engine... LOL) is too big to fit without serious sheetmetal work, and extremely heavy.
Good luck
Evan
Good luck
Evan
Originally posted by 82F100SWB
...needs the 94 up diesel instrument cluster(won't run without it...)
I would really like to go with a bigger engine. I would be nice to have a very strong (high hp) motor and not have to worry about it melting down with a tweaked smaller comparable motor. There was a guy on the turbo diesel register web site that stuffed a 8.3 liter Cummins in a Ford. I would love to do something like this with my truck. Another question if I put a Cummins in my Ford (5.9 or 8.3, I think that the bellhousing will fit both) what kind of manual trans should I look for. I would like to keep my 4x4 and run at farely low rpms on the highway.
on
Steve: I haven't investigated quite that far, but, I believe it may be the tach itself, all I know for sure is that the only one I've played with(a 95) wouldn't start or run with the cluster unplugged,a nd, I only tried that after I'd been told that the cluster was needed.
Evan
Evan
(the 7.3L and ZF 6-speed bolt up...no problems)
Someone please back me up on this!!
Happy Wrenching
-Jason-
I posted on this topic about a Centurion F-350/Bronco conversion doing a diesel conversion at: http://www.fordtrucks.com/forums/sho...613#post935613
Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks and Vans > 1980 - 1986 F-Series Trucks / E-Series Vans > Egine swap 460 to a diesel...Can I??
Shmit90051
31
05-22-2019 09:11 PM
uh60
1999 to 2016 Super Duty
10-30-2016 03:03 PM
DairyFarmer5
09-27-2012 11:47 PM
