1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
1999 f250 triton v10 won't lock at the hub in 4x4
Old 11-26-2013, 07:01 PM
Kirk.ri's Avatar
Kirk.ri
Kirk.ri is offline
Does any one know what a 1999 f250 super duty triton v10 would have for a front axle and why mine won't lock in 4x4 at the front drivers side hub it have warn hubs and will lock in on passenger side but on divers with ether just grind or not go in at all
Old 11-26-2013, 07:05 PM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
you are going to have to pull the hub and look at the components to see what it wrong.
I take it that it won't even turn? (the hub)
Old 11-26-2013, 07:20 PM
Kirk.ri's Avatar
Kirk.ri
Kirk.ri is offline
The hub turns, everything is there I drive the truck daily . I bought it used and he td me it worked but the truck had been sitting. So I got stuck and went to lock them in a bam no 4x4. I can take the hub apart and lock the gear in by hand but it only holds for a min. It's like it's not reaching something when I lock it in..
Old 11-26-2013, 07:41 PM
02TB250's Avatar
02TB250
02TB250 is offline
how do all the teeth look on the hub? it sounds like it might be stripped if it holds for a second and then lets go. or there is something internally broken inside the hub.
Old 11-26-2013, 08:04 PM
Kirk.ri's Avatar
Kirk.ri
Kirk.ri is offline
Nothing's broke I have had it apart and that's why I'm so confused. like I said it's like something's not reaching. Could it be the guy I bought it from used the wrong greese in it or? One day it went in but as soon as I gave it a shot of gas I heard a loud bang but I still didn't see anything broke. Like I can push the gear in by hand and it works for a bit
Old 11-26-2013, 08:11 PM
senix's Avatar
senix
senix is offline
wonder if the wrong hubs for the application maybe? Confirm with Warn that they are the correct hubs if you can find a part number. Since you have had them apart go over the parts list with Warn as well.
Old 11-26-2013, 09:07 PM
Kirk.ri's Avatar
Kirk.ri
Kirk.ri is offline
I'll check next time I take them apart .. Does anyone know what the front axle is?
Old 11-26-2013, 09:09 PM
02TB250's Avatar
02TB250
02TB250 is offline
The front axle should be a d50 in a 99
Old 11-27-2013, 08:47 AM
Kirk.ri's Avatar
Kirk.ri
Kirk.ri is offline
Ok thanks I'll see if I have the wrong hubs
Old 11-28-2013, 07:09 PM
Kirk.ri's Avatar
Kirk.ri
Kirk.ri is offline
I got the 4x4 working.. Took the hub apart and cleaned the whole thing tore it down made sure everything worked .. What it was is the clip that is on the back wasn't put on right and was letting one of the gears slide to far and not letting another ketch. Put it all together and greased it and tryed it .. It finally works. But for how long I don't know but I hope it works
Old 11-28-2013, 07:14 PM
senix's Avatar
senix
senix is offline
congrats on the self repair.
pass1over
01-27-2017 09:30 AM
mrsch06
12-18-2011 07:39 PM
teederj2002
07-25-2004 09:33 AM
Quick Reply: 1999 f250 triton v10 won't lock at the hub in 4x4
