I got 2 questions 2001 f150
2001 4x4 5.4l with 150,000 on it with in the last year I replace pass wheel hub, inner outer tie rods, upper and lower ball joints, stab links, and idler arm. Everything both sides beside the hub.
1st issue is I get a squeal from passenger tire a little lithium grease where the CV shaft goes into the back of the hub stops it for a while the disc brake guard appears to not be contacting the shaft any ideas
Issue 2 at highway speeds I get a vibration throughout the truck when I let off the gas only .seems to start around 65 and up cant tell where it is coming from. Any help would be much appreciated
smilespergallon79
11-11-2016 01:51 PM
